Paul Ferradas's Avatar
Replacing spacer Lug Nuts.
I'd like to replace my lug nuts that attach the spacer to my hub. I'm not sure who makes the spacer or the lug nuts. Can I pick these up at Home Depot or any auto parts store? They are M14x1.5 and the socket head is 22mm. They can't be too tall or else they won't allow the wheel to sit flush.
Thanks,
Old 12-26-2006, 05:26 PM
Danny_Ocean's Avatar
No on HD. Check out your local nut/bolt supply house. Make sure you get Grade 8, minimum.
P.S. - That's not a spacer, it's an adapter.
Old 12-26-2006, 05:45 PM
Thanks for that clarification Danny.
Old 12-26-2006, 05:47 PM
Anyone in the South Bay know of a good nuts/bolts house?
Old 12-26-2006, 05:49 PM
http://www.hillcofasteners.com/
http://www.fastenal.com/web/storeInfo.ex?branch=CASA6
Old 12-26-2006, 05:56 PM
WOW! THat's right by my house. Thanks alot.
Old 12-26-2006, 06:06 PM
I think these will work http://www.fastenal.com/web/products/detail.ex?sku=40334
Old 12-26-2006, 06:13 PM
Your original lugs appear to be nylock while the replacements you linked to do not. I would try to find the same nut. Be certain, whatever you purchase, is rated "Grade 8".
Old 12-26-2006, 06:19 PM
slammed1000's Avatar
Send a message via Yahoo to slammed1000
most spacers take a acorn style lug. take a picture of the spacer without a nut in it. if it is tappered where the nut sits it needs a acorn nut. if it is flat then you can use a regular nut.
Old 12-26-2006, 07:30 PM
Thanks, it's flat.
Old 12-26-2006, 07:52 PM
Oh Haha's Avatar
Paul,
Not to concern you if it's not necessary BUT I have similar spacers but mine are held on by steel acorn lugnuts. Are you sure they are flat sided?
Why do you want to replace them anyway?
EDIT: Let me ask that a different way.
Is the area that the nut sits in dished? It looks as though it is in your pictures. If so, you need acorn nuts.
Pacific Blue
Wayne
Old 12-26-2006, 07:59 PM
Yeah, flat sided. I just checked them. Take a look at the nuts too, they are flat also.
Theyve built up crud on them and thought it would be good to replace them since there cheap and I have both spacer/adapters off. I guess i don't really have to. I certainly won't go searching all around town to find them.
Old 12-26-2006, 08:02 PM
Oh Haha's Avatar
Cool.
Good insurance to replace them while removed. Be sure to torque them down correctly, 91 ft lbs.
Pacific Blue
Wayne
Old 12-26-2006, 08:06 PM
Yeah, I will. Here's a pic of the adapter. It's hard to tell but it is indeed flat.
Old 12-26-2006, 08:07 PM
Different type of adapter, but mine are flat too:
Old 12-26-2006, 08:32 PM
And clean
Old 12-26-2006, 09:02 PM
Irrationally exuberant
ChrisBennet's Avatar
I'd replace them while you have them off.
I'd use all metal lock nuts in that application instead of nylocks.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-27-2006, 04:41 AM
And clean
That's the "before" pic...
Old 12-27-2006, 10:57 AM
T77911S's Avatar
looks tappered to me. put one of the lugnuts off the wheel in there and u will feel it center itself.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-27-2006, 11:14 AM
Paul-
Give a call to Parts Heaven. I bet they have exactly what you need. I think they are open this week.
Old 12-27-2006, 11:26 AM
