Def not "Plug & Play"
Santa finally got off his fat behind and had some guy in brown shorts drop off my Rennline tower strut brace. The package was naturally crushed but everything inside is ok.
In any case I assumed the bar would come somewhat assembled, but here is the state it comes in. I'm sure it won't be a problem, but I didn't expect a sack of bolts and assorted loose pieces: ![]() ![]()
Ken Justice 1985 Carrera (Ruby II) 1973.5 911T CIS (Ruby, gone but not forgotten) 2004 Buell Lightning (aka Elbow-Crusher, crashed) |
Man I LOVE projects like that...so easy, so clean and satisfying. You can have SOMETHING in 20 minutes! I should do more of those, LOL>
BTW, I think thats one of the best units on a very short list of 2.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Yep. A little less than 20 minutes to mock it all up. Figured out why they ship it like that. They have three versions of the bar, single bar, double bar, and triangulated bar. So they ship everyone the single bar kit, and add to it the appropriate pieces for the other two models. That's why everyone says "I can't figure out what these other 2 spacers are for", those are for the base single-bar kit, and everyone gets the same hardware kit regardless of model.
My only gripe so far is the instructions are a bit on the meager side. Doesn't mention that you have to scrape off the goop that's on the towers, or what the proper torque setting is for the bolts or the bars. And when you go to tighten the bars (which acts like a giant turnbuckle between the towers) do you expand (tension to expand towers) or contract (tension to cinch towers together) them before you set the lock nuts?
Hope this helps. Eric
'79 SC Silver over Black... Sold |
In theory, it shouldn't matter whether you go in or out, but folks like to go in to try and pick up miniscule amounts of camber. I haven't done that and actually measured the possible gain, but I suspect it's not significant. Would be interested to hear some real before and after numbers....
Still need torque settings.... Anyone?
I can't give you numbers, but use common sense. The bolts that you remove should be replaced with the same torque. Probably listed in the shop manual on that, as I think you are refering to the factory bolts, right?
As for the rod nuts (turnbuckle), thats tough to get a reading on. Go for solid, but don't throw your body weight into it. If you know what I mean, LOL>
Virginia Rocks!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Regular washers, regular nuts. Looks like stainless to me.
rhymes with targa
hatpix - Is that the dual bar setup or the triangulated setup?
That's the dual bar. Currently looking like this:
'82 911SC racecar '05 WRX STi |
Why stress the body so much? What do your hood gaps look like now?
I'm not the only one who does this, it's a very old club racing "trick". We aren't allowed to use offset camber plates or offset ball joints in the PCA stock classes, also not allowed to machine or grind the factory camber plates, so you get your camber however you can. I still need another degree!
Just got a email reply from Rennline about the install:
Put a bit of pressure inward (Pulling the towers together). Not much, just enough to take up any slop in the brackets and rod ends. No torque is needed. Just tighten them (the bolts that attach the bars to the brackets) up.
Thread Tools | |
Rate This Thread | |
