-   -   Hardest or most frustrating 911 project? (http://forums.pelicanparts.com/porsche-911-technical-forum/322434-hardest-most-frustrating-911-project.html)
mthomas58 12-31-2006 04:42 AM
OK, I'll start.
Getting the Alternator fan back on over the woodruff key without it popping out the backside. I STILL DON'T HAVE IT BACK ON. Gave up last night after about an hour and hit the martini's! I'll be back out trying this AM.
safe 12-31-2006 06:12 AM
If we exclude big projects like body work 3 small projects comes to mind.
* Hood badge
* Hood shocks
* cam timing (keeping timing while tightening cam nut)
Peterfrans 12-31-2006 06:23 AM
targa rear glass install
replacing master and slave clutch cilinders on a G50
aligning door gaps
Peterfrans 12-31-2006 06:24 AM
Not to forget fixing the problems and "fixes" introduced by previous owners
azasadny 12-31-2006 06:25 AM
Trying to replace the large spring on the clutch pedal on the pedal cluster. I notice that the old one had snapped in half when I was replacing my broken clutch cable and I could not get it replaced no matter what I did. I have to remove the entire pedal cluster to replace that spring!!
mthomas58 12-31-2006 06:43 AM
Glad to hear I'm not the only one who had trouble with the hood badge. I could not get the new badge to seat in the new gasket so I had to re-use the old gasket.
felix_browne 12-31-2006 06:46 AM
replacing fuel lines from the tank to the engine cmpt.
mark 74 carrera 12-31-2006 07:26 AM
Absolutley without a doubt? Repainting the nineteen grid lines for the rear defrost on the rear targa glass.
If anyone ever needs to do it, I can tell you what not to do! For one, don't even try to adjust the wiring tabs, they will pop off. Ask me how I know....
http://forums.pelicanparts.com/uploa...1167578733.jpg
RarlyL8 12-31-2006 07:26 AM
- Installing new headliner
- Replacing Targ rear window
MichiganMat 12-31-2006 08:08 AM
Anything involving the CVs
Through-tunnel fuel line replacement
The first 6mo of valve adjustments
Rear torsion bar installation (and DIY alignment and ride height settings)
GothingNC 12-31-2006 08:11 AM
R&R of the Heat Exchangers on a Porsche from the Midwest or North East.
imcarthur 12-31-2006 08:41 AM
Hahaha. I'm glad I'm not the only one . . .
I'll add one:
Sewing the zipper on a Cab top. aka: The bigger the needle the more it hurts.
Ian
Blanco 12-31-2006 08:51 AM
most frustrating..........
running down a no start/ no spark issue.
Went to MSD and now rocks likes a champ!
Vipergrün 12-31-2006 08:57 AM
Wow, no one has said rear spring plate bushing replacement/torsion bar replacement/ride height adjustment.... Kinda like 3 frustating projects in one :)
autobonrun 12-31-2006 09:19 AM
Without a doubt this was the worst project for me. Never again. After using a propane torch to burn off remnants of the old bushings and smelling those vapors, I'm done with this job.
zotman72 12-31-2006 09:39 AM
Forgetting to transfer the starter ring from the old pressure plate to the new one when doing a clutch job. Nothing worse than hearing that whirling noise at startup time and thinking WTF!
KCinBR 12-31-2006 10:12 AM
For me..................Targa Top recover/rebuild, along with fitting the targa top to windshield frame seal.
The good news is the info I gleaned from this board made it all possible.
Next project.........front suspension refresh??????????????
cary 12-31-2006 10:30 AM
I think new headliner has always got the most votes. I just reglued the leading edge under the sunroof. Ended up getting glue in my hair.
BTW I switched to the NAPA brand adhesive. I hate to say it, but it flashes and tacks up a lot better than the 3m stuff.
Couple other good ones on the list. Hood Badge PIA. Then that stupid clevis pin on the bottom of the drivers side front hood shock.
Kind of makes you chuckle at all the profanity events we've had playing with our toys. My grown kids remind me every time I cut them off from cusing. Then I remind them. I'm the Dad. Do as I say, not as I do. LOL.
Zeke 12-31-2006 11:09 AM
rust.
And why would someone "repaint" the defroster lines? Is there some kind of repair applied by a brush? I doubt it, but I had to ask.....
SoCal70RSR 12-31-2006 11:16 AM
How about anything "tunnel" related, like running two new fuel lines. Replacing the tunnel brake line was tough as well.
Replacing the headliner is definetely one of the worst jobs.
