-   -   Hardest or most frustrating 911 project? (http://forums.pelicanparts.com/porsche-911-technical-forum/322434-hardest-most-frustrating-911-project.html)
mthomas58 12-31-2006 04:42 AM
OK, I'll start.
Getting the Alternator fan back on over the woodruff key without it popping out the backside. I STILL DON'T HAVE IT BACK ON. Gave up last night after about an hour and hit the martini's! I'll be back out trying this AM.
safe 12-31-2006 06:12 AM
If we exclude big projects like body work 3 small projects comes to mind.
* Hood badge
* Hood shocks
* cam timing (keeping timing while tightening cam nut)
Peterfrans 12-31-2006 06:23 AM
targa rear glass install
replacing master and slave clutch cilinders on a G50
aligning door gaps
Peterfrans 12-31-2006 06:24 AM
Not to forget fixing the problems and "fixes" introduced by previous owners
azasadny 12-31-2006 06:25 AM
Trying to replace the large spring on the clutch pedal on the pedal cluster. I notice that the old one had snapped in half when I was replacing my broken clutch cable and I could not get it replaced no matter what I did. I have to remove the entire pedal cluster to replace that spring!!
mthomas58 12-31-2006 06:43 AM
Glad to hear I'm not the only one who had trouble with the hood badge. I could not get the new badge to seat in the new gasket so I had to re-use the old gasket.
felix_browne 12-31-2006 06:46 AM
replacing fuel lines from the tank to the engine cmpt.
mark 74 carrera 12-31-2006 07:26 AM
Absolutley without a doubt? Repainting the nineteen grid lines for the rear defrost on the rear targa glass.
If anyone ever needs to do it, I can tell you what not to do! For one, don't even try to adjust the wiring tabs, they will pop off. Ask me how I know....
http://forums.pelicanparts.com/uploa...1167578733.jpg
RarlyL8 12-31-2006 07:26 AM
- Installing new headliner
- Replacing Targ rear window
MichiganMat 12-31-2006 08:08 AM
Anything involving the CVs
Through-tunnel fuel line replacement
The first 6mo of valve adjustments
Rear torsion bar installation (and DIY alignment and ride height settings)
GothingNC 12-31-2006 08:11 AM
R&R of the Heat Exchangers on a Porsche from the Midwest or North East.
imcarthur 12-31-2006 08:41 AM
Hahaha. I'm glad I'm not the only one . . .
I'll add one:
Sewing the zipper on a Cab top. aka: The bigger the needle the more it hurts.
Ian
Blanco 12-31-2006 08:51 AM
most frustrating..........
running down a no start/ no spark issue.
Went to MSD and now rocks likes a champ!
Vipergrün 12-31-2006 08:57 AM
Wow, no one has said rear spring plate bushing replacement/torsion bar replacement/ride height adjustment.... Kinda like 3 frustating projects in one :)
autobonrun 12-31-2006 09:19 AM
Without a doubt this was the worst project for me. Never again. After using a propane torch to burn off remnants of the old bushings and smelling those vapors, I'm done with this job.
zotman72 12-31-2006 09:39 AM
Forgetting to transfer the starter ring from the old pressure plate to the new one when doing a clutch job. Nothing worse than hearing that whirling noise at startup time and thinking WTF!
KCinBR 12-31-2006 10:12 AM
For me..................Targa Top recover/rebuild, along with fitting the targa top to windshield frame seal.
The good news is the info I gleaned from this board made it all possible.
Next project.........front suspension refresh??????????????
cary 12-31-2006 10:30 AM
I think new headliner has always got the most votes. I just reglued the leading edge under the sunroof. Ended up getting glue in my hair.
BTW I switched to the NAPA brand adhesive. I hate to say it, but it flashes and tacks up a lot better than the 3m stuff.
Couple other good ones on the list. Hood Badge PIA. Then that stupid clevis pin on the bottom of the drivers side front hood shock.
Kind of makes you chuckle at all the profanity events we've had playing with our toys. My grown kids remind me every time I cut them off from cusing. Then I remind them. I'm the Dad. Do as I say, not as I do. LOL.
Zeke 12-31-2006 11:09 AM
rust.
And why would someone "repaint" the defroster lines? Is there some kind of repair applied by a brush? I doubt it, but I had to ask.....
SoCal70RSR 12-31-2006 11:16 AM
How about anything "tunnel" related, like running two new fuel lines. Replacing the tunnel brake line was tough as well.
Replacing the headliner is definetely one of the worst jobs.
randywebb 12-31-2006 12:05 PM
For me (so far, & I hope forever) it was putting an early 'road racer' style transmission in my '73 (attached to a 3.2L motor).
azasadny 12-31-2006 12:40 PM
I thought the clutch cable replacement would be the hardest project I ever attempted, but it was easy compared to some of the other things I've done on the car.
djdsc 12-31-2006 12:55 PM
Replacing the heater/defroster levers on the dash and attaching and running new cables under the dash into the trunk.
mark 74 carrera 12-31-2006 01:17 PM
Milt,
The glass has etched lines either into or on the glass. But the current is carried by a conductor that is placed on the glass at the factory. After 32 years and many washes, I guess, the conductor had been removed.
There is a repair kit that can be found on the internet. It is meant to repair and not to completely redo the grid lines. I had to tape and repaint or re-brush (the brush looks like a finger nail paint brush) the grid lines.
As for why would you doubt it? I can't say. Perhaps to be a smart a$$?
Mark
Quicksilver 12-31-2006 01:23 PM
Replacing rear banana arm bushings without removing the engine/tranny. I have a later G50 car and I just wanted little monoballs in there.
BZZZZZT thankyouforplaying...
elflamo 12-31-2006 01:24 PM
Getting the dust boot on the AL front calipers and getting stuck pistons out calipers.
azasadny 12-31-2006 01:26 PM
What?
Originally posted by Noah
It takes about five minutes if you space out the coils on the spring with washers and flathead screwdrivers. ;)
And it would have only taken 10 seconds with the search button to learn that. ;)
Noah,
How does the "washer and screwdriver" technique work? I searched but didn't find that method. I tried to spread out the spring but nothing I tried worked and I gave up. I'd really like to get the spring installed this winter while the car is stored. Thanks!
dezzmo 12-31-2006 02:22 PM
I did that once after I reminded myself not to:eek:
Also, trying to reconnect the throttle linkage to the pedal cluster after it fell down into the tunnell with all the other linkages and fuel lines running thru there!
the 12-31-2006 02:28 PM
rear wheel bearings can be tough.
porsche930dude 12-31-2006 03:50 PM
front hood shock retaining clip was a pita. after messing with it for an hour i had my brother try and he had it on in 30 seconds!
Front fuel pump is a messy job especially with a full tank of fuel and original rubber fuel line
gtihop 12-31-2006 03:56 PM
Here's a funny one!!
After putting on the cam carriers with the engine on the stand, watching a washer fall down the oil return tube into the case!! Then spending 2 hours fishing it out.
Tcannon88 12-31-2006 04:33 PM
So far, the alternator shroud is the worst.... But the hood shocks are in my future :(.
safe 01-01-2007 06:48 AM
That's a big project but pretty straight forward, does not match the "frustrating factor" of the hood badge :)
Paul K 01-01-2007 08:04 AM
1. Convincing the wife to let me buy one.
2. Saving up $17k to buy one.
(Accomplished first, on track for fall of this year with second!)
Cheers,
Paul.
livi 01-01-2007 08:14 AM
Silly but never the less the most frustrating moment so far in my short DIY career: Replacing number six spark plug. That little bugger drove me crazy.
Zeke 01-02-2007 08:34 AM
Originally posted by mark 74 carrera
Milt,
Mark
That pretty well does it for me.
No, I wasn't being a smart ass. If you read what I said carefully, you will see that I inferred that I doubted that there was a viable brush on solution to failed lines on the glass rather than your ability or desire to fix them.
So, I asked if there was such a product expressing my doubt that there was.
As I need to get away from this addiction(Pelican forums), this will help. Thanks.
Jared at Pelican Parts 01-02-2007 08:39 AM
cam timing
rear wheel bearings
Tim Hancock 01-02-2007 08:58 AM
Engine rebuild.....compared to many other types of auto and aircraft engines I have rebuilt, the flat six is definitely the fussiest.
Headliner is not too difficult, just time consuming.
holtjv 01-02-2007 10:09 AM
Re: What?
Originally posted by azasadny
Noah,
Art: I replaced my pedal spring last night. After 1 hour of cursing, I went inside and searched. 10 minutes later it was on. Here's the thread--put a screwdriver in the top hoop and bend it open while holding it in one hand:
http://forums.pelicanparts.com/showthread.php?s=&threadid=314311&highlight=clutch +pedal+spring
3.2 CAB 01-02-2007 10:36 AM
Replacing the cabriolet top on mine. It almost drove me nuts:eek:. It took me several days to do it correctly. I now know why the places charge so much for an entire Cab Top replacement(the front fabric and rear window sections) and I decided that I would never do it again. MAJOR PITA!!!!
