Roll Bar Hardware and Bolt size question...
Does anybody know the size bolts required (Grade 8.8) for the seatbelt locations in a 84 Carrera?
I have some 7/16 20 thread pitch bolts that are not grade 8.8 they fit and are fully threaded, but not sure what grade they are (grade 5 I assume). My guess is since I cannot find them anywhere is that there is a metric equivalent to that size that fits the seatbelt locations. I have found that size but they have a shoulder on them which will not work, I need the fully threaded ones. Thanks -
Jeff |
I know it's sounds a little odd but I'm pretty sure that the seat belt bolts are not metric. The metric equivalent to 7/16ths works out to 11.113mm.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
The old seatbelt bolts have a shoulder on them which will not work, and the head is realy thin - too thin for my liking -
They have REPA written on them and are 8.8 - the threadpitch looks like a 20 7/16 - 20 works fine it is just a matter of finding that bolt in a grade 8.8 with no shoulder...all I could find was a grade 5 Nothing I have found on the internet has that type of bolt configuration so i assume something is up... -Jeff
Jeff |
Driving member
Try this site for the bolts you need.
http://www.mcmaster.com/
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Jeff,
If you can't find what you want at the above link, you might consider buying the hardware from a vendor that sells either race harnesses or roll bars. I would wager that some company (e.g. TRE) that markets rolls bars for the 911 could also supply the hardware to install one. Good luck, JR
Thanks for the link - they have them...!
Jeff |
If MMC fails, there is always the "Nutty Company" in CT.
They ship, nice folks. http://www.nutty.com/
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Sesat belt bolt is indeed 7/16"-20 pitch UNF fine thread....not metric.
Being "non-metric"...you will never find a property class 8.8 or 10.9 or 12.9 strength grade for this size...these are metric designations. Look for Grade 5 or 8. - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thanks for the sanity check Wil
Found the bolts - grade 8 - Thanks
Jeff |
