Send a message via AIM to NoLift911
Roll Bar Hardware and Bolt size question...
Does anybody know the size bolts required (Grade 8.8) for the seatbelt locations in a 84 Carrera?
I have some 7/16 20 thread pitch bolts that are not grade 8.8 they fit and are fully threaded, but not sure what grade they are (grade 5 I assume).
My guess is since I cannot find them anywhere is that there is a metric equivalent to that size that fits the seatbelt locations.
I have found that size but they have a shoulder on them which will not work, I need the fully threaded ones.
Thanks -
Jeff
Old 01-02-2007, 07:51 AM
I know it's sounds a little odd but I'm pretty sure that the seat belt bolts are not metric. The metric equivalent to 7/16ths works out to 11.113mm.
JR
Old 01-02-2007, 07:56 AM
The old seatbelt bolts have a shoulder on them which will not work, and the head is realy thin - too thin for my liking -
They have REPA written on them and are 8.8 - the threadpitch looks like a 20
7/16 - 20 works fine it is just a matter of finding that bolt in a grade 8.8 with no shoulder...all I could find was a grade 5
Nothing I have found on the internet has that type of bolt configuration so i assume something is up...
-Jeff
Jeff
Old 01-02-2007, 08:22 AM
Driving member
jester911's Avatar
Try this site for the bolts you need.
http://www.mcmaster.com/
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 01-02-2007, 08:41 AM
Jeff,
If you can't find what you want at the above link, you might consider buying the hardware from a vendor that sells either race harnesses or roll bars. I would wager that some company (e.g. TRE) that markets rolls bars for the 911 could also supply the hardware to install one.
Good luck,
JR
Old 01-02-2007, 08:51 AM
Thanks for the link - they have them...!
Jeff
Old 01-02-2007, 09:32 AM
lateapex911's Avatar
If MMC fails, there is always the "Nutty Company" in CT.
They ship, nice folks.
http://www.nutty.com/
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 01-02-2007, 11:21 AM
Sesat belt bolt is indeed 7/16"-20 pitch UNF fine thread....not metric.
Being "non-metric"...you will never find a property class 8.8 or 10.9 or 12.9 strength grade for this size...these are metric designations. Look for Grade 5 or 8.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-03-2007, 12:07 PM
Thanks for the sanity check Wil
Found the bolts - grade 8 - Thanks
Jeff
Old 01-03-2007, 01:30 PM
