Cire's Avatar
Send a message via AIM to Cire
Weber Carbs on 3.2 - Idle Jet Questions
Howdy Everyone,
I have a 3.2 in an offroad car and I am having a little trouble with one of the webers. The drivers side responds as it should however the passenger side does not.
When I dial in the idle adjustment screw the engine does not fall off or speed up as it should. So after some reading I was lead to the conclusion that the idle jet passage is blocked. I pulled out the Idle jet and the Mixture Adjustment Screw and squirted a little carb cleaner in. It came out the bottom (when squirting from the top) just as it should.
The engine idles fine however, I know its missing on that cylinder as I can pull the plug wire and the engine doesnt change. When I get on the gas (past the idle jet range???) it seems to come on strong. So when you drive it, its a little flat on the bottom but when it gets to 3000 - 4000 RPMs, it ROCKS!
What am I missing?
Thanks everyone.
Eric
http://ericclark.com/sandrail/newengine/index.html
If it isn't dirty, it isn't fun!!!
Old 01-07-2007, 08:07 AM
gumba's Avatar
did you blow are through the idle jet?
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 01-07-2007, 08:34 AM
I'd remove the idle jet and do an excellent job cleaning it.
IMO.. a partially clogged jet will run very hot EGT under even partial load. If it was completely clogged that cylinder would be completely dead.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-07-2007, 08:35 AM
