Jeff Alton's Avatar
Dumb-Dumb welding question??
Quick welding question for you welders out there....
I have a crack in a wastegate pipe on my 951 where the pipe meets the flange. The pipe is stainless (non-magnetic) and the the flange appears to be cast regular steel. Can they be welded? Can I do it with my MIG? The reason I ask is that they appear to be fused in some fashion from the factory and the replacement part is one piece not a seperate pipe and flange.
www.turn3autosport.com
Old 01-08-2007, 08:58 PM
slammed1000's Avatar
Send a message via Yahoo to slammed1000
if it is cast iron i have had luck with using stainless welding rods and arc welding it...you have to go very slow and make sure that you dont over heat it. you will want to tap on the welds as you weld it. there is a cast iron rod for arc but i have had better luck with stainless.
Old 01-08-2007, 09:23 PM
Jeff Alton's Avatar
Thanks!
Cheers
Old 01-08-2007, 09:24 PM
audi2.7t's Avatar
It can be MiG'ed with regular steel wire . I would take it off and have it TiG'ed though.
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 01-09-2007, 05:28 AM
Jeff Alton's Avatar
Okay, I think I will run it by a machine shop today and see what they say.
Thanks guys
Old 01-09-2007, 06:53 AM
Platinum Member
dad911's Avatar
It's been a long time, but I seem to remember that there was a factory update for that part to prevent cracks???? You may want to post this on some 944 boards.
Old 01-09-2007, 07:02 AM
Jeff Alton's Avatar
This is the updated part!! But thanks!
Cheers
Old 01-09-2007, 07:47 AM
Zeke's Avatar
It helps to preheat and slow cool a cast part. My welding instructor did a CI manifold that way using only a MIG. I didn't see them change the wire, but that's it, I couldn't see all of what was going on. I thought he would have gone into the stick welder booth.
I have Googled such a question and gotten lots of info.
Old 01-09-2007, 07:52 AM
Send a message via AIM to FirstGen
I can TIG it for you no problem. If that would help you out PM me.
Old 01-09-2007, 08:36 AM
Me to if need be..
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-09-2007, 08:54 AM
Jeff Alton's Avatar
Thanks for the offers guys. I will attempt to MIG tonight and with just a tack or two and see what penetration I get.
Cheers
Old 01-09-2007, 11:13 AM
audi2.7t's Avatar
Just FYI, you can use steel MIG wire on stainless and stainless on steel. It just means that the mild steel wire will rust on stainless. For stainless on stainless you need to use Stargon instead of Co2/Argon mix.
'96 Dodge Viper
'09 Maxima
'99 Rottweiler
'08 Cane Corso
Old 01-09-2007, 02:31 PM
Jeff Alton's Avatar
Thanks, If I have time late tonight I will try some tacks and report back. My welding needs practice anyways so if I bugger up a broken part and have to buy a new one, oh well!
Cheers
Old 01-09-2007, 02:44 PM
Jeff Alton's Avatar
Thanks for the tips guys, I used my MIG on it tonight and it welded up just fine. I was able to weld the OD and the ID both.
Cheers
Old 01-11-2007, 08:20 PM
