goober's Avatar
How high to get engine out?
I searched the forum and coun't find the answer. (I'm sure one of you will have better luck!)
I am pulling the engine out of my 84 Carrera. How high do I have to get the car in the air to clear the engine when i slide it out the back?
Old 01-09-2007, 05:01 PM
Oh Haha's Avatar
36 inches should be safe if you aren't removing the rear bumper.
You can gain some room by taking it off but I found that it worked ok on a buddies Carrera. The Motronic system seems to be a little more compact than my CIS system.
PLEASE use secure, big jackstands when doing this. We don;t need to have any injured Pelicans. Be safe.
Pacific Blue
Wayne
Old 01-09-2007, 06:00 PM
North Coast Cab's Avatar
On my '84 it was really high, around the 36" mark. However, you only need it that high for a minute when you pull the engine out. Leave it down while you disconnect everything and get ready, otherwise it's a PITA to get to everything.
1985.5 944 GTS
Old 01-09-2007, 06:13 PM
the the is offline
Scary high - that's the worst part of the job when you are doing it without a lift - getting the back end way up there on jackstands.
Old 01-09-2007, 06:16 PM
I came across the issue that my stands are not high enough. Had to put concrete blocks under stands until I got to the right height. It sounds silly but the car felt more secure being on a stable base with the stands only half extended.......longer stands look less stable. although I have not heard any stories on cars rocking off the stands.
Mark....
Old 01-09-2007, 06:38 PM
Unregistered
sammyg2's Avatar
No no no. No concrete blocks. They have a tendency to crumble at the wrong time. People have been killed that way, it's not an urban myth. I know our porsches are not that heavy but why roll the dice when your life is at stake?
I use a bunch of 4x4 blocks about 16" long, screwed together with a piece of plywood screwed on top for stability. The first two facing one direction and the second pair on top of them and perpedicular.
Old 01-09-2007, 06:44 PM
CabMike's Avatar
Can you use an engine hoist to lift the rear of the car for the final portion of the drop? If so, where would you attache the hoist to best lift the rear up?
Thanks,
Mike
Mike
1983 911 Cabriolet (3.6L conversion)
Guards Red
2007 BMW X5
Old 01-09-2007, 06:49 PM
The conctre blocks are actually pavers about 5cm thick and 50cm square. There is no way of them crumbling. I stack 3 on each side.
Should have been a bit more accurate in my discription.......I have seen people using blocks....and the results of them crumbling.
Mark.........
Old 01-09-2007, 06:57 PM
Komenda Fan's Avatar
Oh, so not like this then either, I guess...
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 01-09-2007, 07:02 PM
FenderGuy's Avatar
That high
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 01-09-2007, 07:26 PM
That guy is just plain scary.......I hear he is advertising for apprentices!
Old 01-09-2007, 07:38 PM
Goldfinger
Mattcamp's Avatar
I think that guy is welding on the gas tank.
Old 01-09-2007, 07:46 PM
but he has great ventilation so any harmful fumes will be wisked away with the breeze from the arriving hurse.
Old 01-09-2007, 07:49 PM
3.4 Bigger is better
88-diamondblue's Avatar
About this high. It is around 36".
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 01-09-2007, 09:19 PM
Send a message via Yahoo to Larry_Ratcliff
I have always take off the back bumper... and gone for the more stable jack stands... always afraid a little earth shaker will come along when I have my car in the air. The back bumper is only about a 30 min removal... then jack stands extended at full range on the torsion tubes will get the job done.
Old 01-09-2007, 09:34 PM
Home of the Whopper
I feel safer using wheel ramps. Once I get the engine on the dolly, I jack up one side a little higher and pull the engine out.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 01-10-2007, 03:54 AM
I used a chain hoist attached to a beam in the attic. As I remember--I'm not sure, I basically just wrapped rope around padding around the entire aft-end crosspiece of the bodywork (the bumper was off) rather than finding any specific weight-bearing piece to attach to. After all, the car less engine/trans is not that heavy when you're lifting the aft end. I was able to do it by hand, in fact, when I got the glass and interior out.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 01-10-2007, 04:42 AM
911mot's Avatar
I just about squeezed it out of there - note blocks under axle stands though. Removing air filter housing and blower motor first would have helped.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 01-10-2007, 05:38 AM
Irrationally exuberant
ChrisBennet's Avatar
Get some tall jack stands and good wheel chocks. It will make your life safer and easier.
For cars with low front spoilers or front spoiler lips (the plastic thing under the front valance) I put some wide boards under the front tires.
Otherwise, the front spoiler may get jammed into the ground when you jack the rear up that high
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-10-2007, 05:44 AM
defcon65's Avatar
My engine runs great, so I'd have to be REALLY high to take it out. I'd probably just detail the bathroom sink with a toothbrush instead.
Regards,
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 01-10-2007, 02:15 PM
