PPI din't find this!
So, I have had this car (83 SC) for about 18 months and there have been no surprises. I drive it drive it frequently in my first 10k miles the car has run like a champ and hasn’t leaked any oil.
Today while changing out the voltage regulator I ran across this; ![]() When I purchased the car it had just had a top end redo to fix a couple of head studs. Looks like JB weld, was this probably done to prevent an oil leak, or could this be a cover for something worse?
83 SC Targa 00 Audi S4, Toyota parts truck |
Air Medal or two
its what some try with a weeping # 1, some times works...
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
+ lurking - contributing
Well it looks bad, but is it leaking oil? If not, I would just add it to the "while I am in there" engine drop R&R. Definitely keep a close eye on that area, though.
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped |
I would leave it alone and fix it when you split the case. That is the only way to fix that baby. I have the same thing, but a drop a week is not going to kill me.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Cool, I was hoping for those kind of responses. I guess you have to expect some suprises with a 20+ year old car. I am glad it took 18m to find the first.
Air Medal or two
There have been long threads on this kind of fix,,..sure it would be nice too tear the whole engine dwn and fix it right....but on the other hand if a gob of goo will sufice....what would you do ?? I know what I would do. !
As I understand it the problem is real common in mag casses, and some alum ones..somehow the oil slips past the "O" ring....never alot just enought to cause you to want to...put some goo on it
isn't there some seal that is replaceable with the engine in the car threre?
1986 944 Turbo - Guards Red |
Nose seals not replaceable without splitting the engine. you can replace the front seal, but that is not the problem.
how can you tell the difference b/t the two different leaks?
Yes I would like an answer to that too. Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Air Medal or two
HMM you can try the seal, and if that dont fix it then its the "o" ring to case problem or a wiggly number 7 bng..like said to fix that its ax time. If I had some kind of compulsory disorder I would split it and fix it LOL.. I Think for me I would wait till something more major came along to warrant that
Front seal is smaller, fits inside the bearing, and if it leaks you find the oil at the bottom of the seal, dripping over the bearing.
Nose bearing seal is the larger seal, if it leaks, you will find the oil on the outside of the nose bearing, dripping down toward the bottom. It seems the previous mechanic had troubleshot it to the nose bearing seal and placed JB-weld around the outside of the bearing to stop the leak. That too is a dead give away. You can spend half a day to replace the front seal with a partial drop if you like. Chances are, $15 buck and half a day gone for nothing. (I did, twice).
abit off center
Some Dow 730 would be fine around the bearing if its leaking. Nothing wrong with that until you can split the case..
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thread Tools | |
Rate This Thread | |
