Super Moderator
Source for "sleeve washers?"
Braintrust:
I'm looking for a source for a particular fastener type. Sometimes called a "bobbin" or "sleeve washer. See pic. Need quantities of 100 at a time. Any help with a source would be appreciated. Running out of ideas. Traditional sources like McMaster, Fastenal, etc.. striking out.
abit off center
Looks like a flanged bushing. What are they made of? Did you check motion industries?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Schleprock
Chris always has to be faster than me. Always..........
Kevin L '86 Carrera "Larry" |
Super Moderator
Steel. Sort of a bushing but traditional bronze won't work.
Finding some promising links searching for "Steel flange bushing"
Schleprock
Flanged bushings are typically too thick, based on what I found
Do I understand correct, threads inside?
If so, look for front sprocket fasteners of bicycles. Lot of different types and materials there, steel, SS, titan, aluminum.. looking like this: ![]()
Roland 930 Turbo '81 Too many modifications to list |
Schleprock
No threads. It's a strange brake hat/bell bobbin assembly
get something like pictured above and finish it on a lathe to your specs. but then 100 at a time might be tough.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 04-10-2014 at 06:35 PM.. |
Super Moderator
We'll keep looking but in the meantime I've got two shops quoting me for making them. Not ideal because they'll cost 10x as much but it's this or nothing for some of our customers....
