jpc1818's Avatar
Easy to put turbo engine in an 89C4
He guys, how easy do you think it would be to put a turbo engine in my C4?
My main concern is if the drivetrain can handle the power?
Any thoughts?
1989 C4 Coupe
1975 911 carrera 2.7rs Sold
1978 911sc Sold
2001 Boxster S
Old 01-17-2007, 04:05 PM
WydRyd's Avatar
You'll be better off turbo'ing the 3.6 in there already! Just remove the pistons and have the crowns machined down to a more boost friendly compression ratio of 8.5:1 (this is done very often). You'll then have the advantage of twin plugs & EFI & AWD
Your drivetrain will handle it... the G50 is a very strong box
964 pistons can be shaved down to within .100" of the deck. That gives you 8.5:1 c/r and has been perfect for turbo-charging.
Even without going inside the engine, you can get 425-450HP at only 0.5-0.6bar
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-17-2007, 05:00 PM
Registered ConfUser
Re: Easy to put turbo engine in an 89C4
Yup...piece of cake. And cheap too!
Old 01-17-2007, 05:25 PM
WydRyd's Avatar
Re: Re: Easy to put turbo engine in an 89C4
Yup, it can be relatively cheap, if you know what to do and who to source the bits from
Merv
'89 911 Turbo Cab
Old 01-17-2007, 09:00 PM
jpc1818's Avatar
Com'on guys. You are teasing me to no extent. Has anyone done this already? Should I pick up a blown c2 turbo motor, if possible, for the parts? Any info would be greatly appreciated.
1989 C4 Coupe
1978 911sc Sold
2001 Boxster S
Old 01-18-2007, 12:58 PM
WydRyd's Avatar
C2T's run archaic CIS injection... you would need to back-date all your EFI in your 964 C4... If you don't believe me, contact Todd Knighton of Protomotive and have a chat with him (knighton@protomotive.com) about turbo conversions for your 964 C4
Merv
'89 911 Turbo Cab
Old 01-18-2007, 03:48 PM
jpc1818's Avatar
Which turbo set-up would work the best? I will search turbos to try to get an answer.
1989 C4 Coupe
1978 911sc Sold
2001 Boxster S
Old 01-18-2007, 05:03 PM
Send a message via AIM to 69 911s
You need to speak to Mike Levitas... that chassis and drivetrain will handle plenty more power and he has the experience in doing it, everywhere from the street to the 24 hours of Daytona.
when you see hoof prints, dont automatically assume zebras
Old 01-18-2007, 05:28 PM
Porsche's Avatar
Might be cheaper and more practical to sell your C4 and buy an earlier 930 if you want turbo.
Erwin
'97 Boxster (sold), '67 911S (sold), '77 911 (sold)
Definitive Australian/ New Zealand Porsche Resources
Old 01-18-2007, 05:30 PM
WydRyd's Avatar
For a 3.6 twin plugged motor, a twin turbo solution is probably best, for ease of plumbing. The twin dizzy would pose some plumbing issues if a single turbo was used, but a good fabricator could work around that.
I personally wouldn't go for anolder 930. You already have the awesome coil overs, ABS, power steering, AWD, working A/C and more comfort
Merv
'89 911 Turbo Cab
Old 01-18-2007, 06:13 PM
Porsche's Avatar
I was suggesting an older 930 only if he didn't want to spend more money and used the money he got from selling the C4 - a 965 would cost a bit more I think.
Erwin
Old 01-18-2007, 06:34 PM
jpc1818's Avatar
Thanks for the input. I love the car, just want more umpf.
1989 C4 Coupe
1978 911sc Sold
2001 Boxster S
Old 01-20-2007, 04:49 PM
group911@aol.co's Avatar
Try supercharging it.
Thanks,
Bob
group911@aol.com
Old 01-20-2007, 05:18 PM
The Unsettler
stomachmonkey's Avatar
Come over to Huntington. See Taso at TKX.
http://www.tkxperformance.com/
Scott
"I want my two dollars"
"Brandon Won"
Old 01-20-2007, 05:24 PM
