easiest way to convert 3 to 5 gauges
my 912 has 3 gauges, how difficult would it be to add the other two (one is a clock I believe). I assume there would be a need to cut the dash as well. Are the early gauges expensive, haven't seen many for sale?
would a 74 dash/gauges fit?
I actually wanted the 3 guage. I wouldn't use a clock, nor do they usually operate correctly and whatever that other guage is I doubt I need. Tach, speedo and temp/fuel and I am ready to rock. I personally thought less was more.
Paper Member
I don't think I'd want a street 911 with less than 4 gauges. Starting from the left on a standard 5 gauge dash you have the fuel gauge / oil level gauge. I could see going without the oil level gauge but since it's a combo gauge why not have it. I definitely would want a fuel gauge in a frequently driven car. The next gauge to the right is the oil temp / pressure gauge. I wouldn't want to go without it. The next two, the tach and speedo, then finally the clock. The clock you could skip for sure but the one in my '65 still works well and the clock in my SC actually keeps better time than my laptop.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
the weird thing is the left gauge i believe has oil temp, oil press and fuel level, so the only difference is with 5 gauges you get the clock and oil level. I just personally like the 5 gauge look on the older pcars
ooh, please don't cut a 66.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Paper Member
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I was actually thinking of a taking a 3 whole dash I have and putting it in my 911 track car I am making. I like the simplicity of the 3. Would you have interest in the 5 pod dash I will be removing?
brian
*NEW 1969 911t targa soft window option 1967 912 Targa Soft Window 1989 911 GP White Cabriolet 1970 911t 2001 Chevy Silverado 1500 1997 Audi A4 Quattro 2.8 2003 Acura TL Type S 1973 911t 3.0 track car (SOLD) |
its going to take me atleast a few days to cut them out of there respective cars. are you in a huge hurry?
Mile,
I will second “ ooh, please don't cut a 66.” A good solution is to build a 3-segment combination instrument like the 914-6 guys do. Fuel level, oil pressure, oil temperature and just use he dip-stick for the oil level (better anyway). Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Come to think of it..I'll bet North Hollywood can make you up a set of custom multi function gauges to drop into the 3 openings
All this cutting and welding of a 66 makes me nervous. I too have a 912 converted to 911 but I have three guages. Poping in a six is only a conversion that will always be a plus, its not like slant noses or whale tails. However the three to five will rest on your mechanical ability so make sure its up there if you start cutting, you only get one chance.
When I think of conversions, and non period correctnes, I often think in terms of reversibility. In other words, if you wanted to convert back to a 912, you might just unbolt the 6 and bolt in the 4, basically. But wehn you get the grinder out, and the torch, things get a little messier.
Of course, its your car, so have fun. BTW, I LOVE my clock...it keeps fine time, and the clicking when I sit in the car and the engines off is charming. I wouldn't change it! (I might addd avolt guage to it though...)
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Has anyone out there added two gauges to a 3 gauge dash? Accurate cutting of a hole xan be done with care. Isn’t there a flange on the inside that supports the gauge?
Wow, talk about a wayback machine!!! This thread is over 10 years old!!!!
Under the radar
What would be the point? Converting to a 6?
Like the others said you could do a triple gauge and use a 930 tach and put either the fuel of volt-gauge in there, in addition to your speedo. That way you'd have 6 gauges in 3 pods.
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
The car is a six cylinder. The 3 gauge pod was drilled and two smaller, uglier gauges were added. The best course is to correct the PO’s handiwork and add the proper VDO gauges.
Still hoping someone has done this before and have some advice. |
