THE IRONMAN
3.2 crankshaft counter rotation (just curious)
I saw on different thread than when we rotate a crankshaft anti clockwise by the cooling fan shaft nut...we can damage the engine...I am just curious...what kind of damage can happen...?
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Friend of Warren
You take the tension off the timing chains. I would surmise you could screw up the engine timing by doing so.
Kurt V No more Porsches, but a revolving number of motorcycles. |
THE IRONMAN
Thanks Kurt...But can we damage the engine if we turn it manually backward...with the cam still linked...?
Immature Member
I want to know as well. Can you actually jump a sprocket at such a low turning rate, even though the tensioners aren't pumped up?
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
I don't think you can cause problems as long as you have the tensioners installed. They pop up pretty strong once you release them.
Maybe if they don't have any oil in them (just air) then there could be a remote possibility of skipping a tooth. I'm sure you would hear it though. -Andy
72 Carrera RS replica, Spec 911 racer |
