Send a message via AIM to johncarlos2003
Door lock: ive read posts but still . . .
Ive read many of the posts on the door locks/acutuator. Recently replaced passenger side door actuator and all was working great. In fact, still does, both sides open and lock properly and efficiently with my alarm clicker or the red button on the console.
The key works fine as well to lock or unlock. Thing is, the door handle is sticky/gummy and the lock wheel won't turn--- what's up with that?
(if this is somewhere and i missed it please put the link and accept my apologies- thanks!)
john-carlos ynostroza
88 G50 coupe, black/black
Old 01-29-2007, 11:36 AM
John-Carlos,
I just had the passenger side door handle off my '85. The screw thar holds it all together backed off.
I noticed the lever was sticky and gummy. Basically got it off the car, sprayed it with W-40, blew it out with compressed air, loosened and retightened the screw holding it together. It finally loosened up.
Essentially cleaning out 20 years of gunk.
Be very careful if you dis-assemble the parts. There is a small spring easy to lose.
Also if the tumbler is installed upside down the micro switch does not work correctly. Ask me how I know.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 01-29-2007, 08:58 PM
Cool- glad it worked out for you. I will have to get in there on Saturday- thanks for the tips. Ill keep track of things and clean her out- the wheel for locking is working-
now, just the stiff interior handle to take care of-
Old 01-29-2007, 09:22 PM
