Kurt B
Guest
Posts: n/a
Okay Warren..what should happen if I pull the connector off temp sensor
If I pull the head sensor connector off and start the car and it idles like ****. Then I touch the connector to the sensor and it stil idles like crap...
Or, is the temp sensor a kind of thing that works After it's been connected for a few seconds (as new data is used by the brain to compute stuff). ...any ideas?
Kurt B
1984 911 Carrera Cabriolet
75 914 1.8
Old 11-23-2000, 01:38 PM
Early_S_Man
Guest
Posts: n/a
Kurt,
With the lead disconnected, it would act just like your car has been idling ... an open is what I suspect your sensor is, currently!
No, there isn't any time delay ... it is a NTC resistor (negative temperature coefficient) just like your oil temp sensor, it either works, or not! And, from your test ... you need a new one!
If you want to test it, use a digital multimeter, and compare with the following:
32 degrees F -- 4.4 to 6.8K Ohms
60-85 degrees F -- 1.4 to 3.6K Ohms
105 degrees F -- 1.0 to 1.3K Ohms
175 degrees F -- 250 to 390 Ohms
212 degrees F -- 160 to 210 Ohms
265 degrees F -- 90 Ohms
You can check at whatever ambient temp is there, but I think you will find an 'open' that is causing your idle problem! You could, of course, test my theory with the same potentiometer 'test jig' for testing your oil pressure gauge! Just dial in 3000 Ohms with your multimeter, hook one side to ground, and the other to the DME lead, start
engine, and smile!
Warren Hall
1973 911S Targa
[This message has been edited by Early_S_Man (edited 11-23-2000).]
Old 11-23-2000, 03:07 PM
Kurt B
Guest
Posts: n/a
Okay, thanks Warren!
Old 11-23-2000, 04:47 PM
