PhD on Pending Projects
Woohooo!!! Parts from GT Racing arrived at Orlando... delivery to my house scheduled for this Wednesday, Oct 3rd
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Parts arrived today:
New fan, housing, alternator: ![]() Rear qtr panels and bumper: ![]() ![]() No brackets on the rear bumper... hummm, more fabrication required... ![]()
Mandatory duct-tape install photos
![]() ![]() ![]() ![]() ![]() It will take some serious rubber to fill those wells... ![]() ![]()
You are a brave man! Kudos!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Dang you provide dangerous inspiration. Great courage.
Matt West 1980 911 SC |
I hate freight charges
You barely have enough room for both those cars in there. Time to "renovate" the garage
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project" ![]() |
MBruns for President
Thats awesome!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
![]() Quote:
I wish I could... That is one of my dreams, building a custom home with a decent 40'x60' workshop... ![]() When we got this house I had them add 2' to the garage to allow for the closet and working bench you see in the back. What I forgot to ask for was a higher ceiling ![]() That would have allowed me to put in a two-post lift... nothing I can do now...
Man this is an interesting thread! Those rear flares make my 11" turbo flares look tiny...
Forgive me if you've already answered this but what are you planning on running for wheels/tires and what do you have planned for an engine? Keep up the progress updates! |
I am scare sh#@$%less on the amount of cutting that is required for the rear panels... time to search in the folder for those photos of others who have done it... I don't want to cut more than is needed and even will try to leave as much original metal as possible...
from the initial looks of the FG panels it looks like I have to remove the rear side glass and cut into the window frame ![]() I need to do my homework now before I make the first cut... ![]()
![]() Quote:
RSR with vented flairs-What wheels are you using?? Looks like I will end up with something like these: ![]() Engine: not too many changes... only plan to put some PMO 46 carbs to give it a better look... when the time comes, a rebuild but not planning on making any changes from the stock components unless is for reliability reasons...
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet Last edited by wachuko; 10-04-2007 at 05:24 AM.. |
-increased overall wheel/tire weight that is unsprung weight. -increased overall tire diameter and it's affect on gearing. I believe the car in the pic above has a 3.6 engine which of course helps overcome the issues mentioned above! Those big meats might be a bit much for a stock 3.0 and stock 915 trans. Edit: Regardless...you've got a very cool project in the works... |
Just a few reference photos of the fender install from other folks here...
Please free to add more from your project or photos you have come across ![]() From JohnnyB: ![]() ![]() From Win Van den Berg RSR (he has been a great source of information for my project, what a guy!!) : ![]() From M325ix ![]() ![]()
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet Last edited by wachuko; 10-04-2007 at 06:54 AM.. |
What did you need the new fan and housing for?
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
A few weeks back I started to hear like the fan was touching the housing... I thought it was the alternator bearings that had gone bad. I removed everything and took the alternator to a repair shop... bearings were fine. After looking again at the fan housing I noticed several cracks... rather than trying to fix those (read a few post here that welding the magnesium housing was going to be a pita) I decided to order a new one.
Porsche no longer makes the housing so I ended up buying a replacement. These come in Aluminum now... BTW, I will be soooo happy when I remove all that CIS stuff and replace it with a beautiful set of PMO carburetors... but first I need to finish all the body work, and get the wheels/tire combo... ![]() ![]() ![]() ![]() ![]() ![]() You can see one of the cracks it in this photo, in the lower left side... ![]() I had to do the new fan housing, new 11 Blade Alternator Fan (also in aluminum), and new 90amp alternator (because I needed the updated alternator to work with all the other parts, housing is for an 84 and requires this alternator)... I also ordered the nice looking strap from Rennline (via Pelican Parts) to go with the changes. Now I only need to decide what color I will paint them (maybe best to powdercoat them since there are all new.... hummm...) So... I have a fine working alternator if anyone is in need for one...
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet Last edited by wachuko; 10-04-2007 at 07:59 AM.. |
When do we move past "Part 1 - The Discovery"??
I move for starting Part 2! Careful with the oversized bodywork and flares and large wheels combining that with limited power to back it up. Don't want to be "all show and no go". Cool project.
1971 RSR - interpretation |
Done! ![]() RSR Conversion - Part 2 - The build
Since I posted the alternator stuff on this one... all other body updates will be done in the second thread started...
Used Tractor Supply paint... very thick/strong paint... Nothing seems to be straight forward... rear bolts on the new alternator are different... so now I have to go out and get the correct size nuts... ![]() ![]() ![]() ![]() ![]() ![]() That is it for this thread... I should start bolting the rear qtr panels tonight to then mark and start cutting the metal... ![]()
subscribe
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
Sorry to say... Car was finished, sold to my friend that helped me finish it...and he sold it a few months ago
![]() I think that it went to Hawaii...
