Rev limiting rotor for '83 RoW 911
I searched but couldn't find definitive info...
I was just replacing my cap & rotor and realized I was replacing a rev-limiting rotor with one which is not. Searches helped me discover the US spec have a normal rotor while RoW's have rev limiting. I don't see a rev-limiting rotor available via Pelican - for my application ('82 RoW SC). Can anyone tell me which one I need? Or, where to source it? Thanks! Skip
1972 911T 1972 911E "RSR" |
Part number should be 930 602 901 02 for the euro SC and 930 602 901 01 (rev limiting) for the euro turbo. Maybe you can use the turbo version.
--Mark-- 1979 RoW 930 1999 BMW Z3 Quote:
rev-limiting rotor for SC
I have the same problem. I want to run the rev-limiting rotor, which came with the RoW cars, in my 3.0L 911. The turbo version, which is available from our host, is rev-limiting, but cuts out at 7k. I am afraid that is too high for my normally aspirated motor. Does anyone know where one can get the RoW rotor ?(Pelican doesn't list it). Wouldn't you be worried if you used the turbo one with a cut out at 7k?
77 911, 3.0L |
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ELignt_pg6.htm#item24
I bought mine from pelican. From memory you just need to specify what RPM cutout you want when you buy it. I got 6500 and I think the options were in 500 RPM increments above and below that.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
