lespaul's Avatar
The BEST stuff to use for . . .
I am overwhelmed by the cumulative knowledge in this forum. In particular, although there is a tremendous amount of knowledge specific to 911's, the members are obviously trained or have substantive experience in many other areas - from engineering, fluid dynamics, electrical work, finish and body work - and years of shade tree mechanical work.
I think it would be very useful to assemble some non- specific to 911, but relevant to 911 maintenance/repair/restoration information about the following topics. So, to start the ball rolling, what is the consensus view on the:
1) Best De-greaser
2) Best Brake Fluid
3) Best Wax
4) Best Gasoline
5) Best Floor Jack
6) Best Transmission Oil
7) Best Engine Oil
8) Best Carpet Cleaner
9) Best Paint Stripper
10) Best Undercoating Remover
11) Best Primer
12) Best Oil Filter
13) Best Tire Cleaner
14) Best Rusty Bolt Penetrating Fluid
15) ????
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 02-09-2007, 07:00 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
The problem with this list.....there are about as many opinions as to which is the best of any one product as there are the number of people who have belly buttons...and boy did I clean that one up....I suggest doing a search for each of your ideas just to see how many you can narrow down to just one....I think you will find its impossible. BUT....it will make for some interesting reading for a few days at least.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 02-09-2007, 07:08 AM
Dan in Pasadena's Avatar
Don is right, you're going to get a million opinions. I may a well give you some of mine up front.
I like Castrol GTX for dino oil and Mobil One for Synthetic. I don't use synthetic in my 30 year old Porsche but have since the beginning in my new-to-me 2002 Dodge Ram Quadcab 4x4
Carept Cleaner - Woolit Rug cleaner. The one for inside your house. None ofthe "automotive" types I've ever used came close.
Degreaser - The Castrol Purple stuff is great though I've had very good results with the much cheaper gallon jug of neon yellow stuff you can buy at Harbor Freight for I think $9.99 a gallon. A lot for the money.
Best Rusty Bolt Penetrating Oil - PB Blaster but I have heard very good things about Kroil
Best Wax - I have my opinion but this is a loaded gun quuestion.
I recently discovered claying through the sudsy water you use to wash the car (wash the real dirt off first then re-suds). That with 3M hand glaze makes my giant black truck shine nicely and no swirls. I find the wax after that doesn't matter as much. I use plain Mothers carnuba but recently tried Zaino and I've got to say I do like it a lot.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 02-09-2007, 07:26 AM
randywebb's Avatar
generally Wurth chemicals will be second to none
Kroil is an xlnt penetrant ("bolt & nut 'loosener'") and stinks a lot less than pb Blaster
BEST can sometimes be so expensive you cannot afford it - floor jacks might fall into that category
also, light wt. ones for racing are nice even if not best in some other ways
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-09-2007, 10:45 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
That's a lot of BEST...
Car wax test results
I use Zaino...and I really think that is best car wax availlable...!
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 02-09-2007, 11:16 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
For the best oil filter...
http://minimopar.knizefamily.net/oilfilters.html
<IN GAS WE TRUST>
Old 02-09-2007, 11:18 AM
19 years and 17k posts...
azasadny's Avatar
My "answers"...
1) Best De-greaser Simple Green
2) Best Brake Fluid ?
3) Best Wax 3M Imperial Show Car Polish
4) Best Gasoline ?
5) Best Floor Jack ?
6) Best Transmission Oil Swepco 201
7) Best Engine Oil ? I use Castrol 20W50
8) Best Carpet Cleaner Woolite
9) Best Paint Stripper Talco Aircraft Stripper
10) Best Undercoating Remover Acetone
11) Best Primer ?
12) Best Oil Filter Mahle
13) Best Tire Cleaner Wesley's
14) Best Rusty Bolt Penetrating Fluid PBBlaster
15) ????
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-09-2007, 11:39 AM
