LinkBack | Thread Tools | Rate Thread |
Ain't it great when you think you have a major problem & and it turns out simple?
I had a mysterious speed dependent "knock" that sounded downright scary. Weird...not in the transmission as it wouldn't change whether in gear, neutral , clutch emgaged/disengaged, etc etc. At times it seemed to be coming from the right rear, at other times from the left front. Crazy harmonics I s'pose.
It did increase in volume but not frequency when the suspension was loaded in left turns...went away in right turns... Jacked the car up and spun all the wheels but couldn't find it. Care to guess what it was? |
CV joint. But, you wouldn't have put up a thread if it was that simple. Probably a golf ball in the trunk.
Milt
THAT was the first thing I checked...especially since I did an engine drop a few weeks ago. Figure some bolts had backed out. But that wasn't it |
Playing card (or road kill) in the spokes?
Kink in the speedo cable (assuming early gearbox)? Sherwood |
Not road kill or speedo cable....
Playing card is warmer, but not it... |
LR wheel bearing?
2021 Spyder 2019 Carrera T 2007 911 GT3 1973 911E RGruppe #295 |
Eleminated wheels bearings as a cause....
Loose wheel stud or cracked Fuch pedal?
Grasping at straws here w/ your playing card hint. What ever it was, glad it's fixed
Nope...not a wheel stud...
give up? |
Bad tire ?
Nope not a bad tire...they're brand new.
But you're getting close.... |
Virginia Rocks!
Rock in the tire.
On my Jeep I once had a child's plastic necklace wedged in the treads... Boy did that make a lot of noise.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
A sticker that was on the new tire.
'82 911 SC |
Not a sticker or a rock...but you guys are on FIRE
Valve cap.
'82 911 SC |
rhymes with targa
Old valve stem\cap inside the tire?
Oh steve....you don't know how close you are...
Here's a hint.... CAMBER CHANGE |
Center hub cap, loose wheel weight...loose nut behind the wheel?
I give up !
Wheel weights hitting?
A socket or wrench left on a nut somewhere behind the tire?
'82 911 SC |
