Dueller's Avatar
Ain't it great when you think you have a major problem & and it turns out simple?
I had a mysterious speed dependent "knock" that sounded downright scary. Weird...not in the transmission as it wouldn't change whether in gear, neutral , clutch emgaged/disengaged, etc etc. At times it seemed to be coming from the right rear, at other times from the left front. Crazy harmonics I s'pose.
It did increase in volume but not frequency when the suspension was loaded in left turns...went away in right turns... Jacked the car up and spun all the wheels but couldn't find it.
Care to guess what it was?
Old 02-11-2007, 04:17 PM
Zeke's Avatar
CV joint. But, you wouldn't have put up a thread if it was that simple. Probably a golf ball in the trunk.
Old 02-11-2007, 04:26 PM
Dueller's Avatar
Milt
THAT was the first thing I checked...especially since I did an engine drop a few weeks ago. Figure some bolts had backed out. But that wasn't it
Old 02-11-2007, 04:30 PM
Playing card (or road kill) in the spokes?
Kink in the speedo cable (assuming early gearbox)?
Sherwood
Old 02-11-2007, 04:33 PM
Dueller's Avatar
Not road kill or speedo cable....
Playing card is warmer, but not it...
Old 02-11-2007, 04:35 PM
Type911's Avatar
LR wheel bearing?
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 02-11-2007, 04:42 PM
Dueller's Avatar
Eleminated wheels bearings as a cause....
Old 02-11-2007, 04:44 PM
Type911's Avatar
Loose wheel stud or cracked Fuch pedal?
Grasping at straws here w/ your playing card hint.
What ever it was, glad it's fixed
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 02-11-2007, 04:47 PM
Dueller's Avatar
Nope...not a wheel stud...
give up?
Old 02-11-2007, 04:52 PM
Type911's Avatar
Bad tire ?
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 02-11-2007, 04:54 PM
Dueller's Avatar
Nope not a bad tire...they're brand new.
But you're getting close....
Old 02-11-2007, 04:57 PM
Virginia Rocks!
VaSteve's Avatar
Rock in the tire.
On my Jeep I once had a child's plastic necklace wedged in the treads... Boy did that make a lot of noise.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-11-2007, 05:01 PM
A sticker that was on the new tire.
'82 911 SC
Dueller's Avatar
Not a sticker or a rock...but you guys are on FIRE
Old 02-11-2007, 05:03 PM
Valve cap.
'82 911 SC
Old 02-11-2007, 05:06 PM
rhymes with targa
Bearded Viking's Avatar
Old valve stem\cap inside the tire?
Old 02-11-2007, 05:07 PM
Dueller's Avatar
Oh steve....you don't know how close you are...
Here's a hint....
CAMBER CHANGE
Old 02-11-2007, 05:08 PM
Type911's Avatar
Center hub cap, loose wheel weight...loose nut behind the wheel?
I give up !
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 02-11-2007, 05:09 PM
Zeke's Avatar
Wheel weights hitting?
Old 02-11-2007, 05:12 PM
A socket or wrench left on a nut somewhere behind the tire?
'82 911 SC
Old 02-11-2007, 05:16 PM
