Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
87-89 Trailing arms different?
All,
I have a question concerning the trailing arm update for early cars.
are the G50 Carrera trailing arms different than 915 SC/Carrera trailing arms found on the 78-86 models?
I found one article here
trailing arm question
but I didnt find an answer unless i overlooked it.
Thanks,
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 02-13-2007, 09:48 AM
syncroid's Avatar
1978 - 1989 911 trailing arms are the same. Part # is 911 331 513 06 The Turbo trailing arms are different.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 02-13-2007, 09:53 AM
durn for'ner
livi's Avatar
There I go. Learning again from you guys.
Had a debate the other day with a friend. I claimed just that - that the trailing arms on the G50 was the same as the turbo.
I should keep my ignorant mouth shut..
Markus
Resident Fluffer
Carrera '85
Old 02-13-2007, 11:25 AM
Black and Blue
Kemo's Avatar
syncroid,
thanks for the quick response. for some reason, I thought the pickup points were a little bit different because of the shorter torsion tube to allow for the G50.
But if they are the same part number, then its the same part!
I should have thought to lookup the part numbers
Kemo
Old 02-13-2007, 11:53 AM
syncroid's Avatar
Glad to be of service.
Dan
Old 02-13-2007, 01:23 PM
