Question 1989 carrera speaker problem, please help!
HI i have just changed the front door speakers and they worked fine. I then changed the rear speakers which work fine, but now the front ones dont! I havent changed any wiring just the crimped on parts which connect the cable and speaker.. can anyone help?
Is there a fuse for this or is this something more major?
Any help would be great guys.
Terry
Old 02-17-2007, 02:22 AM
khamul02's Avatar
undo the wires at the deck. I'm assuming they are crimped or tapes. They key is that you do it at the deck. Then take a 9 volt battery and attach it to the pos and neg wire going to the speaker. You should hear and see somthing from the speaker. You can also do this with a signal/tone generator. What this tells you is that your wireing is good and it's a deck issue. Also, note if two speakers are making a noise when only one should be. That will tell you somthing is iffy about the wiring. It sounds like a deck issue or you have a short in your wiring somewhere. hope this helps.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-17-2007, 09:11 AM
87coupe's Avatar
Make sure it's not something simple like the fader control on the head unit.
ßrandon
Old 02-17-2007, 09:47 AM
khamul02's Avatar
Good point.
Tom Hutchinson
Old 02-17-2007, 10:25 AM
Thanks guys i will check in the morning!
Old 02-17-2007, 10:55 AM
