How do you test the Cold Start Valve
'74 2.7 CIS:
My car runs very well warm, but starting has some issues. Cold: Car starts with throttle lever up & will run with lever down after about 2-3 minutes. Warm: Car runs well but after turning off engine for just a minute (like at a gas station), the car starts and behaves like it is flooded. It sputters for about a minute and will die with out foot on gas or throttle lever up. Just replaced accumulator. Have not replaced check valve but during the accumulator replacement, I noticed that the fuel line was pressurized - this makes me assume the check valve is ok. It's hard to describe how the engine runs while starting warm....but here goes. Putt..........putt........putt.......putt....putt. ...putt....putt...putt...putt..putt.putt.putt.putt .putt.putt.pitt.vroom. So, how would I check the cold start valve & do these symptoms sound like CSV issues? My guess is that it's working but not stopping and therefore too rich at warm startup. Other Recent Tuneup Items 01/2012: all new vacum lines, injector seals, injector sleeves, manifold gaskets, manifold o gaskets, plug wires, plugs, cap, rotor, valves adjusted, fuel filter. Any advice would be appreciated.......Vern Last edited by Tidybuoy; 03-16-2012 at 12:03 PM.. |
vern, do you have CIS pressure test gauges?
poof! gone |
Functionista
I don't think your car would start at all without CSI.
But I'll answer in case you want to test it/back flush it. I used a battery that was at about 11 volts as I did not want to over heat its internal windings. Hook it up and heard it click. Then I reverse flush it with compressed air and injector cleaner mix. You can then check spray pattern by energizing it when you have supply side under pressure.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Checked out
disconnect the plug (thus deactivating the CSV) and see if the problem goes away.
Checked out
(but from what you describe, I don't think the CSV is your problem)
ROW '78 911 Targa
New accumulator defective?
Yes, I have the CIS test gauges. I haven't tested pressures yet but maybe this weekend, I will get to it.
