vash's Avatar
if i install a cat bypass, will i need to adjust my mixture?
just wondering. (i will also, install a gutted stock muff at the same time).
thanks
cliff
poof! gone
Old 02-20-2007, 02:26 PM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Someone that knows for sure will chime in. In my case I did it to the 964 without any additional changes to the car... I would venture to say that you probably will not need to make any changes.
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 02-20-2007, 03:11 PM
sithot's Avatar
You may or may not plug in the O2 sensor. The system will run rich if left out (by default). This was not the most technically advanced emissions setup.
Good luck,
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 02-20-2007, 03:17 PM
I'm with Bill
Rick V's Avatar
I didn't with my 82. I have the Bursch "test pipe" and 1 in 1out. I also have a new functioning 02 sensor.
Old 02-20-2007, 03:54 PM
goat's Avatar
Cliff I did not have to with my car I just made sure the 02 sensor was in place. But your 3.0 might be a tad different than the 3.2.
Tim.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 02-20-2007, 04:07 PM
JBO JBO is offline
You may need (want) to richen it up a little, which is what I did. I believe the newer motronic cars will adjust automatically and those folks don't need to do anything.
Old 02-21-2007, 07:45 AM
YES YES you change your VE with a cat bypass. if all you do is a catbypass then you are wasting your time. Chip your car or richen it....
Old 02-21-2007, 07:54 AM
