3.2 CAB's Avatar
Troy, you mentioned that you have already replaced two of the 3 sensors? Two sensors are the same part #, the speed and reference sensor, the other sensor is the TDC sensor, and it is only used for diagnostic test equipment, it does nothing as far as the operation of the engine, like the speed and reference sensors do. It could be removed, and your engine would not know the difference with it or without it.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-22-2008, 11:24 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Sorry to resurect this thread but any adverse effects on alternative BMW sensors? My Connectors have crumbled and need to be replaced.
'85 Carrera Targa
PCA/POC
Old 01-27-2008, 09:32 PM
No adverse effects so far.
Since they are just sending impulses to the DME for ignition timing there should be no other problems as long as the engine can start and runs on.
The new connectors also make the engine compartment look way better than did those cracked old ones with black silicone glue around the bracket.
'87 3.2 Targa
Old 01-27-2008, 10:49 PM
DRACO A5OG's Avatar
Found two sites selling them for $57 USD.
'85 Carrera Targa
PCA/POC
Old 01-28-2008, 02:26 PM
dshepp806's Avatar
Has anyone compared the signal outputs on these two (versions) WITH an o-scope?
just curious as to waveform similarities..
Thanx!
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-28-2008, 02:52 PM
DRACO A5OG's Avatar
Thanx!
Except for the extra length, would the signal vary if all remaining components are identical? Please edify
'85 Carrera Targa
PCA/POC
Old 01-28-2008, 04:55 PM
buttjoint's Avatar
Where did ya find em for $57.00
Old 02-01-2008, 04:49 PM
DRACO A5OG's Avatar
Update:
The BMW Sensors is maybe less than 1/2 inch longer.
Note: removing the Reference sensor is easy enough due to the fact it is housed by a sleeve and slipped right out. However the Speed sensor does not have the housing and on mine it siezed and could not be removed so I had to remove the bracket to physically tear out the sensor.
If you do not have to replace the speed sensor, don't.
It appears heat has expanded mine and made it impossible to remove by hand.
The sensors are liken to a light bulb, if you twist the sensors to install them you will most likely damage the new sensor, like a light bulb, twisting the bulb beyond it's limits will twist and break the filament wires. Once damamged you will not be able to start your baby.
After 10 hours, I finally gave up and brought it to my wrench and he figured out that I damaged the Speed sensor. He placed a known good one and wouldn't you know it it started right up. Expensive Lessen Learned.
'85 Carrera Targa
PCA/POC
Old 04-22-2008, 11:18 PM
The unsure purchase.....there seems to be several listing of various BMW fits to this part number, 12-14-1-708-619-M14. Anyone have a recomendation or are they all the same.
1984 911 3.2 ref sensor replacement w/bmw part #.
Thanks, Dave
1984 Porsche 911 Carrera
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 08-27-2009, 09:04 AM
Southern Class & Sass
Dixie's Avatar
I simply ordered two BMW 12-14-1-708-619-M14 sensors from Pelican. They've worked perfectly for over a year on my 911.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 08-27-2009, 03:50 PM
KTL KTL is online now
Schleprock
KTL's Avatar
One of my friends is one who confirmed to our local group that the BMW sensors work.
Our cross-reference search yielded the original Bosch part number: 0 261 210 002 which appears to be from E24 635, E24 735, E28 535, E28 533 BMW models. See page 16 of this Bosch application manual
http://apps.bosch.com.au/products/sa...on_modules.pdf.
On Pelicanparts, this equates to the sensor for 535 cars from 1985-1988 and 533 cars from 1983-1984 which is BMW part number 12-14-1-708-619-M14
These sensors are working great (been going strong in Jay's car for two years now), the plugs are the same. So there is no need to buy the Porsche part number!
Kevin L
'86 Carrera "Larry"
Old 08-28-2009, 07:06 AM
Great, thanks for the follow up...ordered 12-14-1-708-619-m14 from out host.
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 08-28-2009, 07:42 AM
scarceller's Avatar
I have used that BMW sensor in the 84-89 Carrera they plug right in! They seem to be the same part as the Porsche part just different number. Will work just fine.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-28-2009, 08:19 AM
"O"man(are we in trouble)
widgeon13's Avatar
Where can I find some instructions on replacing these sensors, I'm in a no start situation on my Carrera and have already replaced the DME relay as well as checked the fuel pump relay so running out of options to get this thing going. Right now not getting any noiuse for the fuel pump but not sure when it is supposed to make noise, is this when the engine is cranking or when the key is turned to the on position.
Old 09-04-2009, 02:38 PM
scarceller's Avatar
Pump comes on engine cranking, put a test light on the fuel pump fuse while cranking the test light must come on. The fuse is in the front trunk fuse block. You can also jumper 12V to this fuse to be sure the pump runs.
Sal
1964 356SC (SOLD)
Old 09-04-2009, 04:31 PM
911 1985 won't start after engin wash
My 1985 911 was working fine, until I washed the engine, now it won't start. Replaced the DME realy, checked the connections to the timing position and speed sensors, and they are worn but seem to be working.
The car will only start in hi idle for a minute in fast idle, the it slows down and starts failing, if I disconnect the Head Temperature Sensor.
Any ideas???
Old 05-20-2012, 10:13 AM
muck-raker
kidrock's Avatar
first thing I would do is check your distributor cap and plug wire connectors for moisture, and completely dry them off....this happens frequently with our cars.
If this doesn't do the trick, unplug your CHT sensor again and jumper the connector (not the sensor) with a paper clip. If your car continues to run while jumpered, you've found your problem.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-20-2012, 10:27 AM
the BMW part is 900 ohm vs 1000 for the Porsche. It makes no difference as long as the ecu sees it.
1971 911S Black
1973 911S 2,4 Targa Hellelfenbein white
1973 911E 2,4 Vipergreen project
1976/77/78 930, Black/Silver/Guards red
BMW 2002ti tracktool
Old 06-10-2012, 11:11 AM
KNS KNS is offline
Micker,
Thanks for the info - so, that is apparently a meaningless difference?
Kurt
Old 06-10-2012, 11:24 AM
Kurt,
No, i have worked with many different setups, and my experience is that sensors in the 4-500 ohm range are quite sensitive to correct gap settings. The "weak" sensors don't like to be further than 0.5mm away.
1971 911S Black
Old 06-10-2012, 11:32 AM
