conversion to 964 twin plug
Ok so I just bought a 993/964 twin plug distributer and need to know, I laymen terms what options I have for hook up. I followed a previous thread where Patton was working on using a 993 splitter, but frankly the "how to" was over my head. I can follow directions, you know, tab A, slot B that sort of thing, but schematics hurt my head. I also understand that I can use a MSD 6al and two coils I assume without the splitter, so Patton if your out there did you come up with a "kit" or do you have a step by step, pics would be helpful!
Old 03-01-2007, 05:24 AM
I can't believe know one has an answer for me! Come on guys.
Old 03-01-2007, 08:17 PM
Somewhere in the Midwest
MotoSook's Avatar
Have you e-mailed or PM him (Patton)? Start there...
Old 03-01-2007, 08:19 PM
Early_S_Man's Avatar
Porsche Crest
It might help if you told what year car and engine you are dealing with??? What is the current ignition system?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-01-2007, 08:39 PM
Sorry it's a 3.2 with motronics. Right now I'm collecting for an eventual rebuild. So here's the list of ideas/parts I either have or need; 993 distributer [just purchased], euro spec or 3.4 pistons, hotter cams[dc 20, or dc21],993 heat exchangers [have], Steve Wong chip [have but will need to be reburned], and one of Ben's mufflers.
Old 03-02-2007, 04:54 AM
randywebb's Avatar
You need the following:
1. the inards from an SC distributor
2. a Bridgeport milling machine with setup blocks
3. 6 more spark plugs
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-02-2007, 01:25 PM
Do you need an SC distributor internals for a Motronic setup? I was under the impression that since advance is controlled by the ECU that the 964 dizzy required no modification. What I know you DO need is a way to split the signal, a second coil, and (I think) the distributor drive gear from a 3.6.
Old 03-02-2007, 02:19 PM
Jeff Alton's Avatar
Search "patton" and "twin plug" the answers are in that thread. He developed an inexpensive way to split the signal and run a 964/993 distributor with your 3.2 motronic.
Cheers
www.turn3autosport.com
Old 03-02-2007, 02:48 PM
