Carrera Cab Connoisseur
Heater Controls Help
Can someone enlighten me on what these controls actually do?
Thanks. Dave.
Dave 1986 Carrera Wide Body Cabriolet 1993 Nissan 300ZX Twin Turbo (620rwhp) 2003 BMW 330Ci MSport Individual 1973 Mercedes 350 Custom Convertible |
Back in New England!
The two controls on the ground (pull levers) physically connect through wire etc to your heater boxes that are in line from you heat exchangers and you hot air tubing that runs to the flapper boxes in you trunk. When you pull the levers up, they cause the vent in the heater box to close so you get more heated air flow. When the levers are down the allow the heater boxes vents to stay open.
Basically they are a way to get more or less heat into you cabin. I hope this doesn't sound too confusing, Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Thanks Matt. Excuse my ignorance but you also have heater controls on the Dash. Are the dash controls purely used with the A/C or are they also heater controls? That is why I am a little confused.
Dave.
There are two types of dash controls. One has two knobs on the top and the other only has one. If you have the two knobs on top the left knob is moved to the right to allow more fresh air into the cabin and to the left to allow less. The top knob (actually these are all levers too) on the right is used to control the speed of the fresh air blower.
The bottom two levers are used to control the direction of the air from the fresh air blower (top, bottom or mix) and the bottom lever (usually red) is used to control the direction (top, bottom or mix) of the air that is coming from your heat exchangers (which the amount is somewhat controled by the levers on the floor controlling the vents on the heater boxes). The middle control switch (above the heater control levers in your original picture) is used to control the automatic heating. I'm too familiar with it because a PO removed mine, but someone else here can pass on good info to you about it. Hope this helps, Matt
Thanks Matt.......got it!......I think.
Dave.
Go out and play with the controls (when you're parked) and they'll make sense to you. This is one of the most painful things to learn while you're trying to drive. Once you realize what each does, it'll make sense to you and even seem like it may be the best way to control you ventilation and heating.
Like Matt said. The 3 speed dial on the top of the console between the seats controls the speeds of the footwell blowers located behind those furry tumors in the left and right footwell. Are they working?
If not you need to do a search on footwell blowers, heating, heater blowers etc. There is a life times worth of info here.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
