wcc wcc is offline
wcc's Avatar
DOT and Non-DOT Approved Brake Lines
What's the difference?
The way they are made?
Quality?
Longevity?
Looking at them side by side in pictures they look the same.
Bill
997.2
Old 03-07-2007, 05:18 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you look carefully...the approved ones have a yellow tag on them!!.
That's the difference.....LOL
Bob
Bob Hutson
Old 03-07-2007, 06:38 AM
Nine9six's Avatar
I believe I read somewhere that the DOT's have an additional teflon liner
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-07-2007, 07:10 AM
Bill Verburg's Avatar
Re: DOT and Non-DOT Approved Brake Lines
Quality?
Longevity?
Somtines but not always the difference is just that the vendor deals w/ race parts and didn't bother to go through the DoT certification process, as w/ all govt beurocasies it is an expensive nightmare.
To be sure of a safe product just buy DoT tagged lines, please do inspect them regularly
Bill Verburg
Old 03-07-2007, 07:22 AM
wcc wcc is offline
wcc's Avatar
Well the price difference wasn't a big deal, so I'll just get the DOT ones. It just made me wonder cause as I was looking around they all looked the same. Dealing with the Gov't makes the most sense to me.
Thanks guys...
Bill
997.2
Old 03-07-2007, 07:38 AM
Diss Member
Quicksilver's Avatar
DOT brake lines are required to have the hose attached using a crimped fitting. The high quality non-DOT brakelines use a threaded AN style connector which when correctly assembled are much more reliable then the crimped connectors.
DOT lines do not have to be Teflon lined. There are plenty of rubber ones out there. As a rule all extreme pressure stainless hoses are Teflon lined.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-07-2007, 09:44 AM
Navin Johnson
TimT's Avatar
Here is an interesting, if somewhat biased read regarding brake hoses
http://www.goodridge.net/usa/pdf/all_markets/Goodridge_stainless_v_rubber.pdf
'69 911 GT-5
'75 914 GT-3
and others
Old 03-07-2007, 09:55 AM
Early_S_Man's Avatar
Porsche Crest
Well, that certainly is a report/hyped sales document worth questioning!!!
Their catalog is bound to be a treat for the ricers!
No brand names mentioned in the report ... doubtful all have same specs, and none I have seen for sale in the USA had a warranty or lifetime claim! I guess Goodridge is trying to make a name for themselves!
My experience during a long-term test of four Earl's [now a division of Holley] PTFE hoses installed on a Datsun 620 truck from 1978 - 94 did not demonstrate superior life compared to OEM rubber hoses! Three hose failures, two at crimp, one mid-hose ... at 8, 9, and 10.5 years installed time. None of the failures involved abrasion, foreign object damage, or accidents ... all were leaks from the Teflon liner. Earl's hoses are now DOT-approved, and I have no complaints about them. Everybody knows you are supposed to inspect brake hoses annually, and I don't think 8 - 10 year lifespan is unreasonable.
http://www.holley.com/types/Hyperfirm%20Brake%20Line%20Kits.asp
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-07-2007, 11:31 AM
I recall an article a long time ago, possibly in Roundel (sorry, used to own BMWs) where it was explained that stainless steel lines weren't DOT b/c it was impossible to view the condtion of the rubber through the stainless steel braided cover. Not sure if that's accurate or not.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-07-2007, 11:39 AM
wcc wcc is offline
wcc's Avatar
I should have been a little more clear. I was mainly comparing DOT and Non-DOT SS Lines and not the rubber ones.
88911coupe - Pelican sells SS lines for both DOT and Non-DOT so I wouldn't think SS braiding would be an issue.
Bill
997.2
Old 03-07-2007, 12:04 PM
