FinallyGotOne's Avatar
Blinker TIP: if the blinkers are blinking fast, usually means a
bad bulb in another light.
If you notice blinkers are not properly functioning, check the opposite bulbs for burnouts or weak connections.
ie. front left seem to blink fast, check rear left for bad bulb.
Also the wrong bulbs will cause problems, even if the fit in there ok.
Old 03-07-2007, 03:05 PM
Senior Member
Superman's Avatar
A poor ground will also cause the fast-blink phenomenon. I'm not sure whether the blinker, tail and brake lights all share the same ground in Porsches but in many cars the dimming of a tail light when the brake pedal is depressed is a sure sign that a ground is not conducting.
Mocha 1978 911SC. "Coco"
Old 03-07-2007, 03:09 PM
mine blinked fast, and then the shop replaced the rear bulb and that did the trick.
Although in my hurry to reassemble my car I put the wrong bulb in the front parking lamp and the whole thing went weird. hazards only flashed on one side, blinker did not blink it just stayed lit etc.../ DUH!!!!
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 03-07-2007, 03:11 PM
Irrationally exuberant
ChrisBennet's Avatar
That's pretty much standard for all cars. I had a fast blink in my 944 even though both blinkers worked. I cleaned the sockets and that fixed it.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-07-2007, 04:35 PM
cantdrv55's Avatar
I had fast blinkers too and it turned out to be the blinker relay inside the dash.
Old 03-07-2007, 06:57 PM
Cooper911SC's Avatar
I'm with cantdrv55...had weird intermitent blinking for quite awhile... tried bulbs, cleaning grounds, etc. etc...turned out to be the flasher relay.
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 03-07-2007, 07:04 PM
