Woodland Hills, CA
Reusing Axle Bolts
Any opinions on reusing the axle joint bolts? Several auto manufacturers recommend replacing the axle bolts when removing them. I was just wondering if that was the case with my 68 SWB 911.
it'll probably work
- Andrew 81SC |
AutoBahned
do you mean the CV bolts?
inspect threads & wrenching feature carefully - reuse if ok replace Schnorr washers each time |
Member 911 Anonymous
My wrench does it all the time. He only replace when they are questionable. +1 on the washers, a must.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
porsher
You can get schnorr washers from porsche but they are rather spendy
Or you can get them from McMaster Carr $11/100 McMaster-Carr and they even come in a bag with the schnorr logo
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Woodland Hills, CA
Yes the CV joint bolts. Thanks for the responses.
Home of the Whopper
Aston, would you happen to have a part number? I would like to order these. Thanks, BK
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Bill is Dead.
Many do. Many do not.
People have differing opinions about the bolt stretch under torque, etc, and many people make their decision based on whether the car is DD or raced. I do not reuse them.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Just did my rear wheel bearings and I replaced them since they have a tendency to strip (Spent 2 hours getting stripped one out) and they're cheap insurance.
that911.tumblr.com |
They're so cheap, I usually toss em. Check out your local hardware store for the bolts.
AutoBahned
local hardware store???
abides.
aka fastenal.com or mcmaster.com
Graham 1984 Carrera Targa |
porsher
![]() here's the # 93501A031
Home of the Whopper
Ordered. Thanks!!
porsher
If anyone is in the Maryville area, BK911 has 100 of the bastards.
I was looking at the Bolt Depot and they are $24/100 for half shaft or pressure plate 12.9s
Bruce |
AutoBahned
be glad you can get 12.9 at your local hardware store
be SURE they ARE 12.9 ... |
We have some good hardware stores here. The bolts I'm talking about are stamped 12.9. And depending on which cv boot kit you use, there are different bolt lengths too.
![]() It seems I have a stripped one....
'65 Porsche 912 (painted dash) #451232 '65 Porsche 912 (painted dash) #451425 - 13 days younger '78 Porsche 911SC - Resto garage queen |
