Dixie Region R Gruppe
w21055's Avatar
Heat Exchanger bolt help needed -where to buy them as well
Ok,
I have had an exhaust leak for a month or so and wanted to fix it.
So I get all six nuts off no problem using the heat method. I go to put the equipment back on and break a stud while tightning the nuts. So I decide to heat the broken stud and it backs right out, awesome right!, Since it was so easy I decide that I want to pull all of them. I get 2 off with no hitch its the 3rd one that snaps about 1/4 away from the block. I have messed with it for a little bit, but wanted to ask for you guys help.
1. What is the best method for pulling one out that is 1/4 away from the block? I am using a MAP torch and don't want to warp anything (maybe not possible just precatious). I know I could drill it, but I would really rather avoid that if possible.
2.Where can I get these besides the dealer (out of stock) and here (would like to finish this by Monday)?
Is it a standard grade stud I can pick up at Home depot?
Thanks for the help.
Phil
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 03-17-2007, 06:47 PM
Band.
I found some for my '72 at Ace Hardware. There's a drawer in the "metric" section of the hardware aisle called "automotive studs". Go figure.
I don't know if my HE studs are the same size as yours, though.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-17-2007, 08:39 PM
you can buy them here at PP for a buck a piece.
Tony G
2000 Boxster S
Old 03-18-2007, 05:35 AM
w21055's Avatar
They are not within driving distance :^).
Anyone know what grade these are?
1992 Ferrari 348TB
Old 03-18-2007, 06:30 AM
KTL KTL is online now
Schleprock
KTL's Avatar
They're std. 8.8 property class M8 x 1.25 pitch. I too got my replacement studs at Ace Hardware. Perfect size/exact match.
Kevin L
'86 Carrera "Larry"
Old 03-18-2007, 08:33 AM
