sensor distance
Dear
I have a 3.2 engine from 1987.
Does anyone know how much the distance should be in "mm" between flywheel en speed sensor (there are 2 sensors located right next to the flywheel; it's the lowest sensor)
Regards
Porscheke
Old 03-21-2007, 03:30 AM
abit off center
cgarr's Avatar
.08mm should be good.
______________________
Craig
G2Performance
Old 03-21-2007, 05:36 AM
Do you mean 0.08mm ???
That is very close?
Old 03-21-2007, 05:39 AM
Slumlord
Porsche_monkey's Avatar
.08mm is 0.003" hmmm. Maybe he meant 0.8 mm which is 0.032 in American.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 03-21-2007, 05:44 AM
So should it be 0.8 mm ???
Old 03-21-2007, 05:46 AM
abit off center
cgarr's Avatar
31 thou, that would be .8mm sorry its early here...
I really just took this out of the book, I was going to give it to you in inches but noted you wanted mm, its printed in the book as .08 which is not correct, the scary part is I just did my own taxes this year
Craig
G2Performance
Old 03-21-2007, 05:49 AM
Ok
thanks !!
Old 03-21-2007, 05:51 AM
