slide a/c compressor?
Trying to change my belt. I've loosened 4 bolts on the a/c compressor mount, should slide. What am I missing?
pat
18,000mi a year 84targa
Old 03-24-2007, 06:48 AM
It's the fan belt I'm trying to change
pat
Old 03-24-2007, 06:50 AM
Make Bruins Great Again
Por_sha911's Avatar
Did you loosen the bolts with the blue or yellow arrows?
Joe
Old 03-24-2007, 06:14 PM
Yes, there's 2 more behind the yellow arrows, right?
Was playing with the adjustment screw on the right but it didn't seem to move the compressor. It's been a while but I thought with those blue & yellow loose it should slide in. Nice looking engine.
pat
Old 03-24-2007, 06:20 PM
Por_sha911's Avatar
You should loosen the 4 yellow and the adjustment screw (not the 4 blue).
Joe
Old 03-24-2007, 06:25 PM
Is it safe to get a bar in there? Seems the belt tension should pull it towards the engine.
pat
Old 03-24-2007, 06:35 PM
Joe , what do you have covering the nut on the fan pulley?
pat
Old 03-24-2007, 06:36 PM
Por_sha911's Avatar
With the proper bolts loosened the unit should slide. Get a bar in where?
The nut is covered by the factory original plastic cap.
Joe
Old 03-24-2007, 07:56 PM
