slide a/c compressor?
Trying to change my belt. I've loosened 4 bolts on the a/c compressor mount, should slide. What am I missing?
pat 18,000mi a year 84targa |
It's the fan belt I'm trying to change
Make Bruins Great Again
Did you loosen the bolts with the blue or yellow arrows?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Yes, there's 2 more behind the yellow arrows, right?
Was playing with the adjustment screw on the right but it didn't seem to move the compressor. It's been a while but I thought with those blue & yellow loose it should slide in. Nice looking engine.
You should loosen the 4 yellow and the adjustment screw (not the 4 blue).
Is it safe to get a bar in there? Seems the belt tension should pull it towards the engine.
Joe , what do you have covering the nut on the fan pulley?
With the proper bolts loosened the unit should slide. Get a bar in where?
The nut is covered by the factory original plastic cap.
