| Registered |
			thanks everyone for the input! I'll happily bow to the consensus and keep it at this height, except for lowering the front a tad more. I'll post a couple of pics on this thread when I get it all assembled and looking pretty. Don.
|  03-24-2007, 07:51 PM |
| Registered Join Date: Aug 2006 Location: SoFLA
			Too low:  I had to raise the front about 1/2"... | ||
|  03-24-2007, 08:01 PM |
| Senior??? Oh very well Join Date: Mar 2006 Location: Wonderful Huntington Beach, again!
			Danny!!! Absolutely WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Stole my heart...thanks for sharing!!! | ||
|  03-24-2007, 08:17 PM |
| Registered Join Date: Dec 2006 Location: Las Vegas,NV
				 |  never too low !   | ||
|  03-24-2007, 08:52 PM |
			Very sweet Darryl, nice stance!
|  03-24-2007, 09:02 PM |
| Registered |
			I like that Darryl, that's gotta be about where I am now. why do we measure ride height from the ground to the wheel opening lip? it seems to make more sense to measure the distance between the upper edge of the wheel and the wheel opening lip. that way tire size variables would be eliminated. and that distance is what you tend to see when you look at the stance of a car. just my canadian $.02 ( about $.018 american). Don.
|  03-24-2007, 09:12 PM |
			haycait911, Thanks, only rubs when i hit the "big unexpected pot hole" or a tight 90 degree turn at high speeds. I was thinking of rolling the fenders? PS; i'm from Montreal living in Vegas, go figure! | ||
|  03-24-2007, 09:18 PM |
| Registered |
			Darryl, I rolled my lips in/upward to clear the tires but didn't put any kind of flare on them. I like the 'narrow' body look with big meats underneath the back. I bet it's a little warmer where you are now  'EH. take off hoser. Don. ( I hope you're not too young to recognize that)
|  03-24-2007, 09:23 PM |
| Registered Join Date: Aug 2005 Location: Naples, Fl
			What brand of tires are you running, tread style looks good. Your silver makes me drool. Buying used limits your choices and mines red, just not my favorite color on a 911. I'm just old and old school is silver on a 911.
|  03-25-2007, 03:52 AM |
| Somatic Negative Optimist |
			Don: Nice car. Too many people sacrifice handling/performance for looks. 2.5 deg negative in the rear makes no sense. If you need to go to that extreme to fit 8's, it's not worth it. Do you have the bump-steer kit installed? You'll be surprised how well a 911 handles when alignment and corner balance are done for performance, not looks. 1 deg negative in the front, 1.5 in the rear is plenty. Toe-in front 1/16", Neutral toe rear. Keep the front lip 1/2" higher than the rear to get that 1 deg nose-down attitude. If you go too low, the shocks/struts will bottom out if the snubbers aren't reduced/removed.
				__________________ 1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats.  Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".   | ||
|  03-25-2007, 06:13 AM |
| Registered Join Date: Jan 2003 Location: the beach
				 | Quote:
				__________________ Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka | ||
|  03-25-2007, 09:23 AM |
| Registered Join Date: Jul 2001 Location: Portland Oregon
			Some observations,.......  Over the years, I've seen a lot of cars that were excessively lowered by either their owners or shops that should have known better. Without question, they certainly looked cool but really didn't handle nor ride very well. When a 911 is lowered a little too much, you run into problems with insufficient suspension travel, roll centers that are too low (or too far apart), and bump steer issues. Further, the camber curves can be FAR from optimal. Suspension travel on these cars is determined by the shocks: if they even momentarily bottom out, your spring rates leap to infinity and suddenly, you are driving a park bench.  When this occurs in a corner, the chances of that tire losing its grip really goes up. One counters this problem by using raised spindle struts and shorter rear shocks. Roll center locations are affected by ride height and when the front end is too low, the roll center is positioned below ground and that increases front lateral weight transfer. This increases the propensity to pick up the inside front tire in a corner. Cars with 4 tires on the ground can corner faster than ones with 3 tires making contact,....  Bump steer rears its ugly head when the car is too low, but this can usually be corrected with a proper bump steer kit such as the Elephant Racing ones. Rack spacers are very limited in what they can do. Finally, suspension geometry range is affected by ride height and its easily to lower these cars to the point where camber gains are excessive and the tires are not flat on the ground for maximum grip. This one is expensive to deal with. I've just touched on these issues and this is a simplification of everything that occurs with these cars but I hope this helps people understand a few of the things that really affect how these cars work so that the handling is not compromised for appearance.
				__________________ Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com | ||
|  03-25-2007, 10:20 AM |
| Registered Usurper Join Date: Sep 2005
			Just a leeetle lower than Euro height...
				__________________ '82 SC RoW coupe | ||
|  03-25-2007, 10:35 AM |
| Registered Join Date: Apr 2006 Location: Newcastle, WA
			Steve, do you have to realign the front end if you install a bump steer kit?
				__________________ James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue | ||
				 | Quote:
|  03-25-2007, 01:37 PM |
				 | Quote:
|  03-25-2007, 07:05 PM |
| Skunk works |
			looks great as it is. if anything the front could be a tad lower. just had my suspension refreshed and lowered. its actually less bumpy on rough surfaces now. just have to be mindful of speed-bumps and driveways...havent hit anything yet here are some crappy phone pics:
				__________________ 964 RS-4 | ||
|  03-25-2007, 08:18 PM |
			[QUOTE]Originally posted by JV911SYDNEY  [B]looks great as it is. if anything the front could be a tad lower. It is obvious that the camp is divided between looks vs. performance. What is laughable though is when "Look-Advocates" are pretending that excessive lowering of stock suspensions is just fine; handles great!........please!   Just whacking it down to impress whom?   Anyone who is familiar with 911-suspensions will know that proper lowering requires some additional expensive work and components. If you just go for looks, at least recognize that there are risk factors involved in whacking it down and that it will not improve performance. Steve gives you an excellent overview of suspension issues. Your choice.
|  03-26-2007, 06:27 AM |
| Registered |
			OK guys, time to put this one to bed. thanks to everyone for the input and technical advice/knowledge. I've raised the rear a bit, front lip now 1/2 " higher than rear. I should be able to get rear camber down to 2 degrees if not a little less. installed bump steer kit. I'll try it like this and raise if need be once I get a feeling for ride/handling. many thanks to everyone again, I don't know where I'd be without you guys. probably have a hole in my head from scratching it all the time. ( get it? head scratching). Gunter, if you're ever heading over to the okanagan drop me a line, I'd like to meet you. Don.       | ||
|  03-26-2007, 11:20 AM |
