Guest
Posts: n/a
Need a tolerance range
I'm intersted in knowing if a set of pistons which mic'd at 89.916mm and cylinders at 89.99 are acceptable for a stock 2.7. ANy info would be appreciated.
BD ------------------ Richard E. Boles |
Guest
Posts: n/a
standard piston size is 89.965-89.975 nikasil
89.952-89.967 alusil piston cylinder clearance should be .0010-.0018 with wear limit of .0031 good luck hope this helps... neil |
