twobone's Avatar
79 3.0 - dropping idle
when I rev the engine and let off, the revs drop to an almost stall, then return to idle.
any ideas?
Garage is empty
Gone:96 TVR Chimaera, 05' Mazdaspeed MX5/89' Caterham Super Seven/84' Carrera/81' 911 SC targa/74' MGB
Old 04-03-2007, 05:00 PM
RETIRED
Joe Bob's Avatar
Try turning the idle up....if it does it only when warm, you may have a vacuum leak or a airbox leak....
Do you have a pop off valve in the air box?
2012 ML350 3.0 Turbo Diesel
Old 04-03-2007, 05:39 PM
twobone's Avatar
no pop off valve
Hi
No pop off valve
Garage is empty
Old 04-03-2007, 05:48 PM
twobone's Avatar
running problems
last summer it was having hot start problems
Could it be related to fuel pressure accumulator issues?
Garage is empty
Old 04-03-2007, 05:49 PM
RETIRED
Joe Bob's Avatar
Hot start can be pressure valve in the neck of the fuel pump....cheap part. The idle is a different issue.....could be fuel pressure related....you need a CIS gauge to test it.
Old 04-03-2007, 05:52 PM
