79 3.0 - dropping idle
when I rev the engine and let off, the revs drop to an almost stall, then return to idle.
any ideas?
Garage is empty Gone:96 TVR Chimaera, 05' Mazdaspeed MX5/89' Caterham Super Seven/84' Carrera/81' 911 SC targa/74' MGB |
RETIRED
Try turning the idle up....if it does it only when warm, you may have a vacuum leak or a airbox leak....
Do you have a pop off valve in the air box?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
no pop off valve
Hi
No pop off valve
running problems
last summer it was having hot start problems
Could it be related to fuel pressure accumulator issues?
RETIRED
Hot start can be pressure valve in the neck of the fuel pump....cheap part. The idle is a different issue.....could be fuel pressure related....you need a CIS gauge to test it.
