Short Shifter Installation problem
I bought a short shifter kit from our host about a year ago and finally got around to installing it today. I've got a problem with the new short shift lever. It looks like it is canted 45 degrees to the right. This might work if i was in the UK with a right-hand drive but doesn't work very well with my car here in Connecticut. Am i missing something here? Anyone else ever have this problem? I will get a picture and post it shortly.
Also, here is what the e-mail from Pelican says that I bought. It sure looks like i ordered the correct thing for my car. 911-424-931-00-M260 $174.00 Factory Original Short Shift Kit, 911 (1974-86)
82 911SC Targa with Megasquirt EFI |
Here are pictures
Yeah, that's messed up. Is the shift lever solid? Usually, the epoxy bonding the top and bottm breaks but that is after years of use. I would send it back. If it rotates you could have it welded.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I was into mine yesterday and indeed that is not indexed correctly - pretty embarrasing for the welder I would think!
Perhaps that is a special build for those that are missing a right hand and need to have the passenger shift. Nope - wouldn't work because the 5th/Reverse tab is also off.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon Last edited by notmytarga; 04-06-2007 at 09:46 PM.. |
Return it to Pelican the bent part has been welded in 90 degrees off. I am sure that it will be replaced at no charge.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip! |
"Some settling may occur during shipment"
Mike B. '72 911E Coupe Early "S" #1065 |
Thanks for the help on this. Pelican is making it right. They are shipping me a new short shift kit immediately and will provide a refund for the bad kit.
Is the pivot piece mounted correct or is it upside down? I just installed it this way and I dont see any difference in the throws.
1986 Porsche Carrera ![]() 1997 Porsche Boxster (Sold) :0 1995 911 Cabriolet (Sold) ![]() 1971 Porsche Targa 911E (Sold) ![]() |
Ruby911
the pivot piece is right in the pic.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
![]() I would suggest after installation and confirming all is well, you tack weld the two-piece lever so it will never separate. ![]() Sherwood www.SeineSystems.com |
Thanks...I drove around a couple miles, what a difference. A few months ago I replaced all the bushings and made things better but the short shift is a smooth operator, no grinding either. Tommorrow I will dump the royal purple transmission oil and replace with swepco.
Thread Tools | |
Rate This Thread | |
