Help w/ Engine #'s
I'm trying to determine what engine is in my dad's 911.
The verticle numbers look like *63D5//64
The horizontal ones are 930 10
Thanks-
Craig Backer
Old 04-08-2007, 12:57 PM
Those numbers don't look right. The engine # does not have letters in it. The 63 might be right but the next number is important. The last 4 are the sequential serial number.
The 930 might be right but the 10 part doesn't jive either. Can you have another look. Use a flashlight and someWd or something to clean the numbers up.
The first 930's were in '76 and started with 686 but the engine type was 930/51.
It is a turbo, but what year is yet to be determined.
Tony G
2000 Boxster S
Old 04-08-2007, 01:12 PM
I actually did use some brake clean and sandpaper. I then parked it in the bright sunlight. Pretty positive on the numbers.
The engine is a 3.0 and is suspected to ROW.
Thanks-
Craig Backer
Old 04-08-2007, 01:19 PM
closest I can find is a 64Dxxxx which is a 930/16 which is a non-turbo 3.0 SC. How about the VIN?
Tony G
2000 Boxster S
Old 04-08-2007, 01:42 PM
Originally posted by tonythetarga
How about the VIN?
The vin's not going to help here seeing as this engine is not original to the car.
What I'm basically trying to figure out is whether this is a us or row engine.
Thanks-
Craig Backer
Old 04-08-2007, 04:22 PM
Vin-barrett's Avatar
a 930/10 is indeed a ROW 3.0
9.8 CR, big intake ports, 204hp
-Vinny
1983 911SC
Old 04-09-2007, 07:01 AM
ttweed's Avatar
The Type 930/10 engine is the '81-83 SC ROW 3.0 w/ 9.8:1 compression, originally rated at 204 HP.
I have one in my '68.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-09-2007, 07:02 AM
Thanks guys. Do these engines run similiar heads and intake to those of the 78-79 usa engines?
Old 04-09-2007, 08:05 AM
Somatic Negative Optimist
Gunter's Avatar
Yes.
But the CR is lower on the US.
8.6 : 1 Me thinks.
The Bosch FD and WUR are slightly different but compatible.
Do you still have the pump?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-09-2007, 08:47 AM
What pump?
Old 04-09-2007, 11:56 AM
Gunter's Avatar
The US '78-'79 have a big air pump for emission control.
Not sure if the Euro's had one?
Old 04-10-2007, 08:26 AM
ttweed's Avatar
The air pump was gone on my '83 930/10 engine when I got it, but the air injection nozzles were still in place in the exhaust ports, and the tubing led back to the engine bay, but was plugged off there. I removed it all and plugged the ports to install headers (the air injection manifold interfered with the fit of the headers.)
TT
Tom Tweed
R Gruppe #232
Old 04-11-2007, 07:08 AM
