Tired Member
Where does this spring connect? '78SC
Last fall after I pulled the engine for some cleaning and a "while I'm in there" list that got bigger than I liked, I ended up with an extra spring. It bothered me for a couple days but everything ran well and I soon got over it.
Well, while browsing our host's catalog I found this diagram showing the spring! I now know where it goes... sorta. Can anyone tell me exactly where to connect it? And what its purpose is?
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
That spring attaches to the middle intake runner on the underside, and then to the throttle linkage arm on the throttle plate.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Tired Member
Nope. I know which one you are talking about and I have that one in place.
![]() The spring in the first post is a called a "support spring" and has something to do with the heater system. It is a different size and has a different part number than the one you referenced. 911-211-143-00-OEM vs. 911-110-165-02-M100
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec Last edited by DaddyGlenn; 04-12-2007 at 01:13 PM.. |
I must not have one, of course I'm backdating now anyway, but I don't remember ever seeing that spring.
That spring does not show on the PET diagram for a '78 SC. Were did you get that particular diagram? That square-ish clamp that holds the splitter duct to the fan is also not on that PET diagram.
Tired Member
I have an '80 SC Euro also -- never seen that spring or the square-ish collar in our 25 years together.
Any chance you could be mistaking it for the spring that's supposed to go between the clutch's small lever arm and the transmission case, on the bottom of the car? Looks awfully similar, and for the first 6 months I owned my car I unwittingly drove around without it.
Hi Glenn, I have a similar spring on my SC 3.0 attached to the throttle linkage (as a return help I imagine) behind the heater blower above the CIS.
Mike. |
