RETIRED
The solenoid comes with the starter....SR68X....
Still should consider the ignition replacement.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Automotive Monomaniac
There are two starters available from Pelican. They are "rebuilt Bosch" ($173) and "high torque" ($249). Which do I get? Will one last longer or perform better?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
RETIRED
One requires a core and is the same price as the "new" one without. I've never used the high torque one but have heard good things.
As an example...my last "rebuilt" came with a card good for one free tow if the starter failed. Didn't give a warm fuzzy feeling.
9.5+ out of 10, it's the starter, if it won't start hot, but starts after cooling down.
Band.
I had the exact same problem last year in my '72. When hot, no cranky. After sitting an hour or two, started up like a dream. I was very close to replacing my starter (and I probably will anyway), but I had a hunch and pulled my tiny miata battery and went back to two interstates in parallel. Haven't had a problem since. Perhaps my miata battery didn't have the nuts to turn that hot almost binding starter. That said, It's probably a temporary solution and I'll be buying a starter soon. Glad you didn't have to tow, though!
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
