930 Trailing Arm Retrofit
What exactly needs to be changed to retrofit 930 rear trailing arms to a 911?
Torsion Camber Box? Axles? Stub Axles? Rotors? Thanks, John
1985.5 944 GTS |
Re: 930 Trailing Arm Retrofit
Yes. Yes. Yes. I am putting '86 930 arms and brakes on my '73. I replaced the torsion bar tube with that for an '86 930. Then everything else just stands to reason. With the big 930 calipers, you may have to go with the 23mm master cylinder. |
