Alright....
The car dies when the oil cap is removed...
New 3.2 owner here, had a 2.7. I took it around the block to warm up the engine and when I went to check the oil level, as soon as I remove the oil cap the car dies.
What am I doing wrong? I just did an engine swap so anything is possible.
Stephen Friendswood, Texas '78 Targa w/ '86 930/20 w/ '74 915/06 |
Vacuum pressure I think, the car does hunt a little at idle when mine is removed but it really shouldnt kill the car.
good luck!
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Virginia Rocks!
It means you probably have a second vacuum leak. What's the idle like before you removed the cap? Mine is usually at 950, and when I removed the cap, dropped to 300.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Alright....
The breather hose was cut when I got the car so I fabbed one up. I wonder if they have a check valve in them or something.
I figured that was it but had to ask. I guess I can just disconnect the hose and block it off when checking the oil.
Alright....
Idle is about 1k before I remove the cap. It is possible I missed some lines before I installed it. I do have a rough idle but I am running without the O2. Was told I could run without it and just have a rough idle.
I think it has something to do with a restrictor that is supposed to go in the vent tube that attaches to the oil tank and the air box.
Taking off the oil cap is creating to much of a vacume leak. Just a guess.
Silver 1980SC Euro coupe |
SCWDP- Shock and Awe Dept
A piece of round aluminum stock that will fit in the hose w/ a 1/4 hole through the center should work fine.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Alright....
So on the 3.2's they only require a small line to vent the tank.
Also check the infamous vacuum port on the backside of the intake. Should be on #3 intake runner.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Actually there is a restrictor in there on the 3.2, p/n 930 107 289 00.
clamp the breather hose with a vice grip or pliers and then take the cap off. If it dies then you have a leak somewhere else. If it doesn't then you are missing the restrictor mentioned above.
'83 SC |
Great advice Chris.
Alright....
Yes! The simple approach worked. The car idles with the hose clamped. And yes, the car was low on oil!
Alright....
I went to Lowes and picked up a .75 cent copper 3/4" gas pipe cap. Drilled a 1/4 hole in it, then placed it in line and put a hose clamp on the outside. Works like a charm! I'll consider buying the $18 OEM part later when I want to upgrade......
Registered abUser
