Bandwidth AbUser
Is this a real project or is it just a race car fantasy camp?
Jim R. |
Me like track days
One can spend time, money, get wrapped up in the passion, the thrill of doing something different while building for them the ultimate car.
Build it, enjoy it, think of what one could do "better".......and then move on to something else. The thrill of the hunt, and perhaps a seeking of the next customization of the upcoming build. I could see Dane building a high HP, low weight Turbo car......one with a ducktail and an intercooler underneath. I'm taking bets ![]()
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
It would be sacrilegious to put a twin turbo into a 934 replica. 930 with EFI will do the trick (I know EFI is cheating) but it will provide the drivability you seek.
Below is my build sheet for my 930/934 project Project Type 930/1987 model/ 37343 miles Engine Stock crank and oil pump, etc. Case boat tailed Pauter rods 3.4L 7.5:1 pistons Cylinders and heads ported with custom head work, 964 style head gaskets 930 heads ported with stock valve sizes, but smaller 993 valve stem diameter on inlet valve. Valves back cut for flow improvements along with some more secret headwork Twin plug with Bosch silver plugs W4CS Imagine Auto valve springs and titanium retainers GT2 Evo custom grind cams Carrera 3.2 liter intake manifold Extruded and honed Custom billet fuel rails Edelbrock pressure regulator Siemens injectors 72lb/hr Full bay intercooler from Bell intercoolers (Don Enderlein’s design) B&B Headers (retained) Fabspeed Dual out exhaust Imagine Auto’s HF2 Turbo Tial BOV, Wastegate MoTeC M600 with Data logging M & W double ended coil M & W CDI controller Motec switch on the fly boost controller with hidden Valet Kennedy Engineered Products Pressure Plate Carbon Fiber shroud Transmission Custom G50/50 Patrick Motorsports with Guard Chromoly LSD, Motorsport steel synchros and sleeve assembly WEVO G50 shifter Suspension I have upgraded to an RSR coilover setup and Wevo Camber king setup with the strut brace tube. Braking and Running Gear The car presently has Big Reds all around and 17” Ruf classics (17x8.5 and 17x 10 with Michelin Pilot Sport Cups). Safety Full fire suppression is onboard and a custom built Chromoly roll bar. Bi-xenon H4s, Recaro Sport Toplines in suede and leather Miscellaneous: McIntosh head unit and amplifier sound system with ADS speakers and JL sub, Griffiths and Performance Aire AC
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
![]() Does it really matter? I build fantasy projects every day on a much smaller scale for well heeled customers. Nothing wrong with having a dream yourself. Pelican is the best place in the world for free advice on Porsche info. How better to start this project? I think any of us who have done one big project (Craig, Matteo, Jack, Doug, Randy and the dozens of others here) will always have something in the back of their minds once the first is done. The first project may well drag you through some serious labor pains and kill any desire to do a second. Or it just may add passion to the first thought process. I think I can "build" an even better car now so why not put that experience (which wasn't cheap) to work and build or even just talk about a different project? No matter, I'll want the next one down on paper (build and budget) before I or anyone else turns a wrench. Call it "updated 934, project proposal". Great feed back guys. Couple of questions? Thinking out of the box. Down sides to starting with a G50 Carrera or a C2? Going to strip amost every thing anyway. I stared thinking from the feed back a C2 might be a better starting platform for rigidity, tranny, suspension and brakes. How hard are the offset issues to resolve or would you? And then back dating. ( chrimney I all ready start thinking a 964 RSR might not be a bad thing and a bit cheaper) What am I missing on a back dated 964? Here is what I am thinking to better the 934, LWT weight, more hp and better suspension. 996 TT would be very cool for the raidiators and HP? More comments? What shop (be cool if a Pro would jump in) do you think should/would take on this kind of project? I won't micro managage another car build. Last one drove me crazy on the details. Looking for a shop that happily covers all the details of a big project liek this upfront. I think few of us realize just how much of an effort TRE put into BBII to have it 100% the day it left the shop. Quote:
15"s for show and 17"s or bigger for go. |
Me like track days
Hey Dane -
Come over and drive my car. See what a CIS turbo motor can feel like. Lag? What lag? And more throttle response than you could ever imagine. Always good to build subjective as well as objective data points.
Awesome SCHNELE! Got any pictures ?
![]() Craig care to share your build sheet? And where is that famous flame thrower picture of your beast? Last edited by rdane; 04-27-2007 at 09:07 AM.. |
Me like track days
Based on your recent thinking, you ought to think seriously of a C2 Turbo.
http://www.c2turbo.com/ The brakes are already present, the suspension easy to modify (coils), power steering and A/C too. Light weight? They are PIGS.... Due to the C2T rear suspension (unless you RSR it), there are definite limitations on rear tire size (285?) for a C2T. ..OR you could build a RUF Yellowbird Replica. That'll drive you crazy ![]()
Friends of Warren
Dane
if you seriously want to improve the suspension geometry you need to look at using a 993 tub for 2 reasons. 1) the tub icomes already more rigid than anything Porshe built before. 2) Rear multi link design As per the engine.... I think it is a sacrilege to have a 934 withOUT a flat fan set up sooooo.... Yes the 996TT engine suggestion was made a little tongue in cheek.. just to stir things up but the 993TT engine is the logical power train solution. I know Craig ans SCHNELE have fantastic 930 engines that are just perfect... But I bet they are close to triple the cost of a used 993TT engine. Remember in stock form with restrictive headers the 993 motor put out 408HP. These days a lot of people are good reprogramming the stock Motronic unit... but a Motec M600 is only $5k and in the big scheme of things... I still think you need to find a use for the extra holes in the valance (originally I thought I could use them for small A/C condensers or for extra small oil coolers+fans).... As per the shop... there are the usual suspects on the west coast and in Oregon... but I would feel bad if i didn't spend a word for Zuffenhaus, the guys that are building my car. I wish you could see the car in person... Ask James Shira.... |
Bandwidth AbUser
Jim R. |
Friends of Warren
Dane
Don't worry abt centerlock wheels and hubs... when the time comes I'll hook you up with the right guys ![]() |
Me like track days
*3.4L P&Cs 7.5:1
Twin plug IA Fuel Head (may not be required) *Adjustable WUR - 3 way / RPM activated solenoid - by Brian Leask *K27 Hyflow 'S' zero clearance turbo Blownsix Intercooler *SC heads 964 cams Aase springs & Ti retainers ARP bolts MSD CD ignition w/Magnecor wires B&B stainless headers No air injection, cold start or plastic CIS manifold 3 oil coolers *Zork (no muffler) * If you want the high HP....
I want something differrent. So a factory car won't be it. LWT? I can make anything lighter. That technology I do possess!
Yellowbird? Funny how that name keeps coming up. Like when Pete was pedal down in 3rd doing well over 100 and says how slow my car felt on the first good section of road on the loop. Then he mentions it is a comparison to Yellowbird, the last car he had out on the loop. Meanwhile I'm thinking "Geezus just how fast is this guy going to drive my car??" And there are people who actually think I like to drive fast? Next time Pete and I get together on "the loop" I want to hear just one thing from him in that first section..."holy sheeetttt!!!!!" All in a good way of course ![]() So the plan is to better Yellowbird which would seem easy enough to do. ![]() Last edited by rdane; 04-27-2007 at 09:26 AM.. |
Me like track days
Then come over to Kirkland & see what a P/W ratio of 5:1 feels like.
Seriously. Take a test drive.
Me like track days
Compare the length of this run:
http://home.comcast.net/~craigcarolann/trackvideos/930_November_11_2006_dyno_009.mpg To this (the old 3.6, 20 more HP than your 3.6): http://www.youtube.com/watch?v=QzfPeeu7BBI That is what more Hp feels like.
Friends of Warren
- 993 tub backdated to 934 look
- centerlock hubs + 962 17" wheels - 993 GT2 transmission + Guard GT2 LSD - JRZ/Moton adj shocks + ERP components - 520HP mild tuned 993 engine (k24 turbos, remap, bigger cooler) The problem would be the tail. The 934 tail does not have enough room for big intercoolers (remember they used the water-to-air intercoolers up front). You'd need to be inventive there... But it would be bye bye Yellowbird any day and you could take it to the grocery store, smog it and drive it on 91 gas... |
Band.
Either one has gotta be pretty ******* fast.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Me like track days
BTW the area in which Dane & I live - if the chassis is 1983 or earlier.....no smog.
Craig I'll take you up on that offer for a ride, next track day if that is OK? Just reread the GT2/2.7 RS comparison. Less than 10 second on the track. No big deal when you are talking street cars. I've already ran my 3.6 against a '05 GT2 so I know where they are at. Everyone keeps up. But going from 7# per HP down to 5# per HP really is a big deal. Matteo? or any one? - 993 tub backdated to 934 look - centerlock hubs + 962 17" wheels - 993 GT2 transmission + Guard GT2 LSD - JRZ/Moton adj shocks + ERP components - 520HP mild tuned 993 engine (k24 turbos, remap, bigger cooler) Makes perfect sense to me. Any idea where we could get down to weight wise with an actual interior? |
newb.
-That being said, it is virtually impossible to cover all of the details of a custom build before the work begins. More realistic is a good outline/action plan. For instance, starting with a C2 over a 930 radically increases the fabrication work for the exterior. Starting with a 993, even moreso. A C2 sacrifices about an inch in rear hub-to-hub from a 930, so deep wheels shouldn't be an issue there. However, centerlocks (although not inexpensive) are already in kit form for 930 suspension and brakes. A 993 would be a great platform in terms of rear suspension, but adds rear quarterpanel grafts to the fabrication list. Both the C2 and the 993 need dashboard backdates. Once a GOOD approach is decided upon, a decent build sheet/estimated job cost can be developed. Once the work starts, and the unexpected options arise, a certain amount of project creep is guaranteed. All that being said, this kind of thing is still the reason we come to work in the morning. give us a call - 704-821-2546 or shoot an email - zuffenhaus@mindspring.com !
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
Thread Tools | |
Rate This Thread | |
