Tired Member
DaddyGlenn's Avatar
Help me build my project list
Later this summer I will be pulling the camshafts to have them reground to a 964 profile. I'll be sending the cams and rocker arms to Camgrinder.
I'd like to start purchasing the other miscellaneous parts now to spread the financial pain over a couple months.
I am however not sure what gaskets and gadgets I will need to replace while I'm in there.
So what should I add to my list for this project?
P.S. I have the tensioner upgrade already.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 05-01-2007, 07:28 AM
Tired Member
DaddyGlenn's Avatar
Chain ramps? Which gaskets will need to be replaced?
Anyone? Anyone?
Glenn
Old 05-01-2007, 01:17 PM
81 911 SC's Avatar
Are you doing a full rebuild? You might need head studs, vavle guides things like that.
- Tyler
1988 911 Carrera Grand Prix White/Black
2015 Cayenne Diesel Black/ Luxor Beige/Black
Old 05-01-2007, 01:24 PM
Tired Member
DaddyGlenn's Avatar
I have no plans to do anything other that regrind the cams and rockers. I had the engine out a few months ago and took care of the usual "while I'm in there" stuff.
Glenn
Old 05-01-2007, 04:04 PM
dweymer's Avatar
Glenn:
Cam oring-2
Chainbox seal-2
chainbox cover gasket-2
Curil-t
cam oil line crush washers-as needed
chains and ramps
chainbox to case gaskets-2
rsr rocker shaft seals-since you are there
Donnie
Currently Porsche-less.....
Old 05-01-2007, 04:53 PM
Tired Member
DaddyGlenn's Avatar
Thanks Donnie. That's what I'm looking for. Do I really need to replace the chains? What is Curil-T?
Glenn
Old 05-01-2007, 06:06 PM
dweymer's Avatar
no, but they stretch, how many miles? Curil-t is a sealant used on the cam o rings(ithink). Check the rebuild book, or i can look for u
Donnie
Old 05-01-2007, 06:17 PM
efhughes3's Avatar
Upgrade your valve springs.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-01-2007, 07:49 PM
Tired Member
DaddyGlenn's Avatar
Geez! I didn't even think about the rebuild book. It is coming off the shelf now.
Glenn
Old 05-02-2007, 03:30 AM
Tired Member
DaddyGlenn's Avatar
OK...never mind..... the list is on page 156 of the rebuild book.
Thanks again Donnie.
My chains have about 85,000 miles on them. They should be good for a while, shouldn't they?
Glenn
Old 05-02-2007, 05:35 AM
