Tired Member
Help me build my project list
Later this summer I will be pulling the camshafts to have them reground to a 964 profile. I'll be sending the cams and rocker arms to Camgrinder.
I'd like to start purchasing the other miscellaneous parts now to spread the financial pain over a couple months. I am however not sure what gaskets and gadgets I will need to replace while I'm in there. So what should I add to my list for this project? P.S. I have the tensioner upgrade already.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Tired Member
Chain ramps? Which gaskets will need to be replaced?
Anyone? Anyone?
Are you doing a full rebuild? You might need head studs, vavle guides things like that.
- Tyler 1988 911 Carrera Grand Prix White/Black 2015 Cayenne Diesel Black/ Luxor Beige/Black |
Tired Member
I have no plans to do anything other that regrind the cams and rockers. I had the engine out a few months ago and took care of the usual "while I'm in there" stuff.
Glenn:
Cam oring-2 Chainbox seal-2 chainbox cover gasket-2 Curil-t cam oil line crush washers-as needed chains and ramps chainbox to case gaskets-2 rsr rocker shaft seals-since you are there
Donnie Currently Porsche-less.....
Tired Member
Thanks Donnie. That's what I'm looking for. Do I really need to replace the chains? What is Curil-T?
no, but they stretch, how many miles? Curil-t is a sealant used on the cam o rings(ithink). Check the rebuild book, or i can look for u
Upgrade your valve springs.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Tired Member
Geez! I didn't even think about the rebuild book. It is coming off the shelf now.
Tired Member
OK...never mind..... the list is on page 156 of the rebuild book.
Thanks again Donnie. My chains have about 85,000 miles on them. They should be good for a while, shouldn't they?
