73 updating to SC trailing arms and calipers?????
I was told that I need the E-Brake from the later year, that my 73 stock set up wont work with the later trailing arms. Is this case?
Richard
Old 05-03-2007, 06:15 PM
randywebb's Avatar
check the p/n's on PET if no one replies
I posted a bunch of what works with what a loong long looooonnnngggg time ago - doubt if you'll be able to find it on the search engine.
doubt if it is the e-breake - more likely CV joint matching
I do know you can put '77 arms on a 73.5 - I did it.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-03-2007, 08:38 PM
joefrantz's Avatar
No brake issues with mine either ('76 arms into '73). E brake shoes are the same, as are the calipers. You should be able to use the stub axles from the '73 for CV compatibility. You'll need shorter 14mm lower shock bolts. THe shocks mount to the steel arms with a bolt and nut. They're threaded into the aluminum arms (no nut) and the older bolt will bottom. I think it needs to be at least 5 mm shorter, but measure to be sure.
Good luck
Joe
Joe Frantz
73 911 T
Old 05-03-2007, 09:24 PM
Senior Member
Ron,K's Avatar
I found this article helping when I changed mine several years ago...
Ron
69 911T
Old 05-04-2007, 06:30 AM
Downloadable PDF files here:
http://members.rennlist.org/911pcars/AlloyContrlArms.htm
Sherwood
Old 05-04-2007, 03:37 PM
joefrantz's Avatar
Just remembered -- You'll need a new hard brake line from the hose to the caliper -- here's a link with pictures and part numbers.
Brake Lines Alloy Trailing Arm Conversion
Joe Frantz
73 911 T
Old 05-04-2007, 10:31 PM
