KCPSG's Avatar
turn signal flashing too rapidly????
I installed new bumpers front and rear, and after installing the signal lights in the front bumper I get a real fast flasher...not a slow flashing like before.
Does anyone else have any experience w/this? is there a fix for it. The original lights had both the side marker or parking lights and then the signal lights but now the lights need to act as both parking and signal lights.
My past experience w/other vehicles tells me that either the flasher is going out or that one of the other bulbs has gone out. But all lights are working just flashing too rapidly.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 05-06-2007, 09:59 AM
Carrera Cab Connoisseur
nyne11's Avatar
Just a thought!
Try upping the wattage on the globes to slow it down?
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 05-06-2007, 10:12 AM
don911's Avatar
I had the same issue when a tail light bulb was corroded. I'd guess a bulb is either out or isn't making contact.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 05-06-2007, 10:21 AM
Sports Purpose 911 Driver
mjshira's Avatar
sounds like you have the right idea here, check you other bulbs, probably one is out. good luck
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 05-06-2007, 10:29 AM
KCPSG's Avatar
all other bulbs work...I think that NYNE11 might be onto something though since I originally had 2 other bulbs for the parking lights that maybe I am not drawing enough voltage fot them to flash properly. I am going to try the higher wattage bulbs...see if that helps any. Thanks for the responses....and of course if any other ideas come to mind let me know,
Phil
1998 BMW 328i
Old 05-06-2007, 10:54 AM
IROC's Avatar
Whenever this has happened to me, removing the bulb and cleaning the contacts and then re-installing it has fixed the problem.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-06-2007, 11:14 AM
bigchillcar's Avatar
it's a bulb issue..seen it several times before myself.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-06-2007, 01:07 PM
Driving member
jester911's Avatar
One of the lights are out when it flashes like that.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 05-06-2007, 01:19 PM
David's Avatar
My turn signals are flashing too fast after replacing my driving lights with brake ducts. Since all four turn signals work, I guess the disconnected driving lights are causing the problem. Does this sound correct? Any easy work around when removing the driving lights?
Old 12-02-2007, 02:17 PM
bad turn signal relay will cause this as well, but i'm guessing it's a result of the work you did in this case.
Old 12-02-2007, 02:44 PM
David's Avatar
I plugged the driving lights back in, replaced a bad tail light bulb, made sure all the other lights are working and they're still flashing fast .
I guess I'll try a new turn signal relay.
Old 12-02-2007, 02:52 PM
RussR's Avatar
it's probably good to cheak if you have an earth leak as well, thats another reason to make the indicator bulb flash fast.
Old 12-02-2007, 04:25 PM
David's Avatar
If I can find the turn signal relay, I'll change it. Bentley shows it to be behind the oil temp/pressure gauge so I pulled it out and I can't see crap. Is this where it is and if so where exactly? Thanks!
Old 12-06-2007, 04:35 PM
it's back there..you may have to remove the adjacent instrument in the cluster as well to reach it if i recall. anyway, there's a couple of relays back there. look in the pelican parts catalog, they may have a picture of it.
Old 12-06-2007, 07:03 PM
I found the easiest way to get to the relay is open the hood and you can access it behind the guage on the right side.
Old 12-06-2007, 10:05 PM
UnRegistered User
billybek's Avatar
If you have deleted some of the lights that originally flashed when the turn signals were on, then it probably is a draw issue.. Less lights= less amps.. It is the amperage that makes the flasher flash. Be careful if you decide to put in higher wattage lamps to compensate. Plastic lenses could melt as a result..
Bill K.
Old 12-07-2007, 05:55 AM
David's Avatar
I finally got around to messing with it. It was the flasher relay. The easiest way to change the relay was reaching through from the trunk. It's the first relay when reaching in from the truck or the relay farthest from the instruments.
Old 12-13-2007, 04:44 PM
good. i wish i'd remembered the easier way for you to access it, but it's been 4-5 years since i'd changed the one on my '74.
Old 12-13-2007, 05:25 PM
Funny, that's exactly what the ricers like on their cars, fast turn signals!
Old 12-13-2007, 06:51 PM
durn for'ner
livi's Avatar
What I thought too. Must be the relay. See it on the kids ricers all the time.
Markus
Resident Fluffer
Carrera '85
Old 12-13-2007, 06:58 PM
